whistlepig
Elite Member
Bobrip - I think Goose is misinformed as well, however a 1.25 HP is not possible unless you have a sequential soft start special motor/pump ala Grundfos. Submersible pumps are either 1/2, 3/4, 1, or 1.5 HP in MOST residential apps. From 300-1000' the pumps are usually 3 wire, single/three phase 2-5HP with the control box (start caps & controls) above ground.
At 300' down you either have a 1HP or a 1.5HP two or three wire pump. The pump size depends on the static water depth at the driest point in the season at the maximum draw rate or required flow. Our pump is a 2 wire 1.5 HP set at 360', with a high water of 80' and low water in the dry season at 200' drawing 7-8 GPM.
Bottom line is you need a Amprobe meter to balance the load on the generator after you buy/install the one you think you need. It seems the issue is what to buy. With a well in general a 5KW would be minimum and 7-8KW would be optimal for a whole house system.
Whitslepig - thats a nice generator you have!
Thanks for the compliment. We bought our farm from a couple going through a nasty divorce. We got blamed for "stealing their dream farm". The previous owners were uncooperative to say the least. I do know the well pump is 220V but nothing else. I had to size our generator for the worst possible scenario on the well pump. The 6500 watt Honda will power our well pump easily. When the well pump kicks on I can hear the generator power up out of Auto-throttle. It doesn't labor the generator. We power our two fridges, the well pump, pellet stove, TV, and some lights. This is all done via extension cords. A dedicated quick disconnect for the 220V well pump. The dedicated 220V quick disconnect was $200.00 installed by a professional electrician plug and play. Not all that difficult. Not all that expensive after the initial cost of the generator. This is the set up every one around here uses.
