skid shoes or not
   / skid shoes or not #1
Anonymous Poster
Epic Contributor
I plan on using a rear blade for snow removal this winter and am trying to decide if I should be using skid shoes. My driveway is paved and I guess I was thinking that if I used the shoes I would'nt able to scrap right down to nothing. But on the other hand, the shoes will probably keep me from re-landscaping the lawn along the edges.
Any replies back on others experiences would be appreciated.
Thanks.
   / skid shoes or not #2
I use a rear blade to plow my gravel driveway. I tried to use skid shoes last year (like those that are on a pickup truck snow plow), and didn't like them at all. Like you, I had hoped they would keep me from "landscaping the edges of my lawn", and also from digging up the driveway. I used them the first time I plowed; what a mistake. They did a pretty good job of digging up the driveway (I should have waited till the ground was frozen/w3tcompact/icons/frown.gif). So I took them off and tried them again after the ground was frozen. I was unable to adjust them well enough so that they would not scrape some gravel, and still remove nearly all of the snow. I gave up and didn't use them again. Now I just use the heighth control on the 3 point and that works pretty well for me.
In your situation, with a paved driveway, you may fare better than I did, although you may want to wait till the sides of your driveway are frozen so the skid shoes don't dig up your lawn. Good luck with whatever you choose to do.
Corm
   / skid shoes or not #3
I have found, based on suggestions previously given here, that it works really good to use the back blade turned around backwards -- in other words have the convex side of the blade toward the direction of travel -- for the first few snows until the ground is really frozen. This way, the blade does not dig in at all.
   / skid shoes or not #4
While we're talking about plowing snow with a rear blade, do most people
1. Drive in reverse and push the snow
or
2. Drive forward and pull the snow
   / skid shoes or not #5
I was scraping my driveway night before last. It tried the blade in a number of different ways. No doubt the way that worked the best was driving forward with the blade reversed.
Kevin
   / skid shoes or not #6
Kevin,
Did you have the blade angled at all? I've not used my blade for snow yet and I do not understand how reversing the blade would be effective.
Terry
   / skid shoes or not #7
Yes, what I ended up doing was a pass down the middle of the driveway with the blade straight. I had the blade the regular way and didn't like the way it was ripping up the gravel etc. So I reversed the blade, angled it and made passes up and down moving out from the middle until the edge of the driveway. The results were pretty good. I think that is how I will do the whole thing.
I did run the whole thing with the blade fully lowered into the "float" mode. Seemed to work pretty well.
Kevin
   / skid shoes or not #8
I drive forward with the rear blade pointing forward. I don't have problem with the tires packing the snow because I have the FEL down in the float position....
   / skid shoes or not #9
Mike,
I drive in reverse and push the snow. Here is a photo of my old tractor with the back blade on.
   / skid shoes or not #10
I generally plow going forward, fel up, rear blade angled to windrow the snow. This saves the neckache of plowing backwards. It is a bit tricky until the ground freezes. Also make sure the blade is flat on the ground. This is where the adjustable 3rd link comes in. run it in or out in length until the blade is working flat on the ground. It will still be necessary to develop a feel for plowing, but if one side of the blade is digging, nothing will help.
2013 Chrysler Town and Country Van (A50324)
2013 Chrysler Town...
2014 MAC CXU613 Semi (A50514)
2014 MAC CXU613...
2018 GENERAC MAGNUM PORTABLE S/A LIGHT TOWER (A51243)
2018 GENERAC...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2011 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
