Skid Steer connectors
/ Skid Steer connectors #1
Robbie Hegwood
Platinum Member
Georgia
Would those of you who have skid steers please list what brand, model, h.p. if you know and what the hyd couplers are. I'm looking for three connectors on the low flow circuit. A supply, return, and case drain. Thanks
And for those close to Mcdonough, Ga please list what city if your comfortable with that.
/ Skid Steer connectors #2
Robbie, several manufacturers use the "Faster" manifold. The big Gehls and Tak for sure. I have also seen the same manifold on other machines but I would not be sure enough to specify which ones. Check out the 4FFI manifold at fasterinc.com. Hope this helps.
/ Skid Steer connectors #3
Hey robbie,
my quick coupler manifold connectors all have "Farster" stamped on them and they all seem to have numbers starting in the FF designation...at least the ones i can still read...Italian ??
2004 cat 257B HIGH FLOW
2 low flow
2 high flow
1 case drain
2 aux
16 GPM low circuit
26 GPM high circuit
I had a difficult time getting HIGH Flow connectors for the mulcher..Even the sales person couldnt get them aftermarket...
I had to take the hoses off the mulcher and bring them to the CAT dealer for the correct match on the high flow circuit and the case drain...
The low flow circuit connectors i purchased at Tractor Supply for the Grapple...
I know this doesnt help you since there are no measurements given of the connectors themselves..I could mic them perhaps? or are you looking for the type of thread?...jic-8,12,14,16..blah blah...
/ Skid Steer connectors #4
you are on the right track..I think what Robbie is looking for is much like what I posted in the thread a few days ago about Hi-Flow...the thread size for the manifold ports where the quick couplers attach..which can be gotten from the numbers you saw stamped on the couplers (unless there is a reducer in between them like on ASV's) and also what type of threads they are JIC, O-ring face, SAE O-ring etc etc etc I may be wrong but I think thats what he is looking for...he will correct me ;)
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2001 VERMEER E550 VACUUM (A60736)
2001 VERMEER E550...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
Sellick S80 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
