SLAB ON GRADE
   / SLAB ON GRADE #11
You cannot pour the footers and floor all in one for that type of building at least the ones I have worked on you pour the floor after the building is up to fasten it to the footers.
   / SLAB ON GRADE #12
We used a "haunched" (spelling?) slab (12' x 26') for our breezeway between the house and garage. The footings are 4ft deep by 1ft wide and filled with 3/4" clean stone. The edge of the slab is 1ft thick concrete while the center is 6" thick. No rebar.
So far, after 10 years, there are no cracks.
PT 6x6 posts sit on the outer edge of the slab to support the breezeway roof above.
   / SLAB ON GRADE
Can I place 12" footers @ grade on 6" stone and use 10 inches of stone under 6" slab to make up the difference. I prefer monolithic pour to minimize time and get tractor locked up under roof ASAP.
   / SLAB ON GRADE #14
Check with some area cement contractors and see what they say about setting it up that way.
   / SLAB ON GRADE #15
I'd say if you have good draining soil this haunched design will work. If you have clay or wet soil the frost will go right through the slab and footers and might heave the building. It's always a shock how easy frost lifts something big and heavy.
Everything hinges on how well drained the site is. That and what the building inspector/code has to say about it. For common sense though, if the frost can't get under the footer, you're ok. Some 1" EPS foam will keep frost from going through the slab, and keep down the sweating in summertime too.
Jim
   / SLAB ON GRADE #16
The area the hauched slab is located is very well drained. No chance of any water getting under the slab. I also put 4" of rigid foam insulation between the crushed stone and slab. And just in case the breezeway ever gets closed in for living space I put PEX tubing in the slab.
   / SLAB ON GRADE #17
Sounds like you did the work already? No input from the building officials?
If not, the haunched slab will work just fine.
Jim
   / SLAB ON GRADE
Yea, I'm going to end up with a foundation you could build the empire state building on till I'm done. Need to go at least 42" deep for frost, 12" wide with 6" slab. Who knew.
   / SLAB ON GRADE #19
Well, it's nice not to have to think about it any more. Until you want to change it!
Good luck,
Jim
   / SLAB ON GRADE #20
CT uses the 2003 International Building Code for out buildings on residential properties. Table R404.3 shows design requirements for a monolithic type slab on grade with (2") foam board insulation around the outside perimiter of the slab. A piece of foam goes verticle against the concretel and a piece lays flat against the verticle piece around the perimiter of the slab. Sort of L-shaped. The crushed stone is to help provide good drainage under the slab. The foam board is an alternative to a full frost-protected footing and concrete wall 42" deep (CT frost depth). This is common design for smaller buildings such as yours. Find out from your Building Inspector what version of the code your town uses and do a little re search to see if this may be acceptable for your area.
RPK
Moxy MT30S Haul Truck (A55272)
Moxy MT30S Haul...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2014 Jacobsen AR3 3-Deck Commercial Rotary Mower (A56857)
2014 Jacobsen AR3...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2022 Ram 2500 (A55973)
