Slasher swing back blades binding up
   / Slasher swing back blades binding up #21
We had some older Terrain King mowers at work that used to double up the blades on startup and get stuck just like that, but they were hooked to a stump jumper though. The only way we could get them to go reliably was to engauge the pto a couple hundred rpms over idle. .. then everything seemed to work just fine. Between that and the cheep gearboxes I was happy to see them go.:)
   / Slasher swing back blades binding up #22
This is first one I have seen without a round disc, stump jumper.
If that was mine, First I would try and retrun it for a model that had a stump jumper on it. If that couldn't be done, I would get a piece of thick walled tubing ID dimension to fit over the taper of the upper plate where gear box shaft bolts on, cut length to fit between the 2 plates and sandwich it in there. The blades would contact the tubing before sliding in between the 2 plates.
2014 F-150 STX (A56438)
2014 F-150 STX...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2018 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2018 KOMATSU...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2016 Lincoln Navigator SUV (A59231)
2016 Lincoln...
