Slip clutch or shear pin??
   / Slip clutch or shear pin?? #1
santacruzer
Santa Cruz, CA
What is generally prefered on a roto tiller...a slip clutch or shear pin?
Thanks for the help! Paul
   / Slip clutch or shear pin?? #2
This may open a can of worms. My tiller has a slip clutch. If a slip clutch is adjusted properly I believe that they are just fine. My experience tells me that many are not adjusted properly. They can sure cost alot of money to repair if they are not adjusted properly and inspected periodically. The slip clutch on my Simplicity tiller was damaged and not adjusted properly when I bought it. I did not remove the cover to inspect it (duh). It broke and cost me about $100 to repair. I'm glad I was able to repair it as the cost to replace was over $250. You could sure buy alot of shear pins for $100.
Mark
   / Slip clutch or shear pin?? #3
My Landpride tiller came with a slip clutch. They were available either way. In the manual I think they strongly recommend loosening the clutch adjustment way up so it will slip and run it a little slipping to shine it up and remove any rust, etc. Then retighten it to normal setting. If you don,t do this, the clutch may not slip when needed, so it would be worse than a shearbolt. If you excercise it like recommended it does work great. The shearbolt setup has the advantage of simplicity, the clutch offers convenience, especially in rocky soil or other tough conditions.
   / Slip clutch or shear pin?? #4
When adjusted properly slip-clutch is the way to go. Be it tilling, rotary cutter 'Brushhogging' or whatever. If the implement finds somthing it cant chew threw the clutch slips, you notice no tilling or mowing, lift implement, pull ahead to clear obstical, lower implement and carry on. Shear bolts-pin you have to stop, get off tractor, line up shear bolt holes on yolk and shaft, install bolt-pin... Clutch set-ups cost more, with once a season maintinace of loosining, slipping and adjusting properly I have exellent luck with them. And not had to leave the tractor while tilling, cutting, getting more done, and more seat time:D
   / Slip clutch or shear pin?? #5
santacruzer The bigest broblem with a shear bolts is when they brake, they will more than likely be replaced with a regular bolt or even [as I have seen] a grade 14 bolt. Only use a shear bolt from the dealer, buy a few extra. If you use a reglur bolt you no longer have a shear pin. As I was fixing my neighbour's rototiller he said [I haven't had any problems with that shear bolt since I replaced it with that really good one]
   / Slip clutch or shear pin?? #6
I'd prefer a properly adjusted slip clutch. If working in rocky soil one can go through a lot of shear pins. :D
   / Slip clutch or shear pin?? #7
The slip clutch is the better option for me. There are many people that like shear pins better because they require no maintenance before use. Finding rocks just under the surface when tilling is all to common of a problem where I live and I would spend much more time putting in new pins than I would adjusting the clutch once before use.
Wolverine Hydraulic Slope Mower Skid Steer Attachment (A55787)
Wolverine...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
New JMR 40" Skidloader Grapple (A50775)
New JMR 40"...
2019 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A53421)
2019 John Deere...
S/N: 2136118 (A55853)
