3-Point Hitch slip clutch pto shaft
   / slip clutch pto shaft #1
naildriver
Jackson, Michigan
Kioti, CK30
What is the purpose of a slip clutch pto shaft as opposed to a regular pto shaft?
   / slip clutch pto shaft #2
To slip when load is very hi. Like you hit a stump with your bushog or tiller.
   / slip clutch pto shaft #3
A slip clutch will slip when the torque on the pto shaft exceeds a given thresh hold. This is done to prevent damage to the tractor or implement.
If a slip clutch is not used then a shear pin is often used. The pto shaft is held onto the implement by a single bolt of a given hardness. When the torque on the shaft is exceeded then the bolt snaps protecting the tractor and implement.
It is not normal for the torque of an implement to exceed its rating except if it has encountered a problem. Some examples would be: a Bush hog hitting a stump, a rototiller getting a rock stuck in it, a baler trying to bale a large branch.
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
2025 GPS Trailers GTT7167K 16ft. T/A Flatbed Trailer (A56858)
2025 GPS Trailers...
2006 Yamaha Grizzly 125 2x4 Utility ATV (A59225)
2006 Yamaha...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2017 FREIGHTLINER...
Giyi 66" Rock Bucket (A57149)
Giyi 66" Rock...
