slip clutch
/ slip clutch #1
hernando
tennessee
dk 4510 kioti and a 450 case track loader
ok i must be nuts , i have a bushhog with a slip clutch , but i didnt set it up so this is my ????,,, please no laughing,,oh ok go ahead,,,,i bought a new tiller ,,the pto drive shaft came with a slip clutch ,,where this slides on the gear box there is a bolt with a nut .i cant seem to figure this out ,it wont slide on because of the pin that holds it on the gear box is in the way..how do i do this ??? i hope i have explained this well enough... i am not really that stupid ....am i ??? thanks for the help......bruce
/ slip clutch #2
I'm not 100% sure what you mean, but if there is a bolt currently through the splined shaft that comes out of the gear box on the tiller. I am assuming that is the bolt you use to hold the slip clutch onto that splined shaft. The bolt would need to be taken out, then put the clutch on and line up the holes in the clutch with the holes in the splined shaft and put the bolt back in and tighten securely. Of course, without seeing what you have there, I am doing a lot of assuming. A picture would help.
/ slip clutch
thanks for the reply.. the shaft that comes out of the tiller is just like the pto shaft that comes out of the tractor...but the pin works just like the end that connects to the tractor only it has a threaded rod with a lock nut that holds it in place on the tiller out put shaft...i just cant get anything to move but the lock nut ...sorry for the confusion,,i really have no idea about this thing..all i have ever had on other equipment is a shear pin and it hooked up normal... i must be getting old ,,,,thanks bruce
/ slip clutch #4
ok.. from what you are saying, you have a slip clutch with one end on the implement gearbox.. those ends are splined ends, and there is a bolt that goes thru it with a locknut on it to keep them together.. sounds like you got the nut off.. but the bolt won't come out?? am I correct so far?
put the nut back on, but not all the way.. now tap on it after spraying with penetrating oil.. the bolt is lickley just rusted into the bore.
if this is the issue, post back and let us know.
once you get the bolt out.. you may find the splines are rusty too.. ( more oil! )
soundguy
/ slip clutch
thanks soundguy ,,you were right on it ... sometimes i cant see for looking...thanks again bruce
/ slip clutch #6
well, did ya get her seperated?
soundguy
/ slip clutch
yes i did...thanks for your help ,, bruce
HUSKY AIR COMPRESSOR (A63569)
HUSKY AIR...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
AUCTION STARTS HERE @ 9AM (A63291)
AUCTION STARTS...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
