Slow leaking tire with rim guard.
   / Slow leaking tire with rim guard. #1
massey collector
Michigan
1938 Massey Harris 101 Or which one
Appers I have a slow leak in a rear R1 tire on my 2017 L3301 Kubota tractor with Rim Guard. Tire showed signs of being low so I added air, then after setting a couple days I saw some thing wet looking in the tire that was on the sticky side, I assume is leaking rim guard.
Do these tractors have intertubes? If so I need to find some place that can remove the rim guard and fix the leak.
IF it is tubeless I may be able to plug the tire or have it plugged.
:D Al
   / Slow leaking tire with rim guard. #2
Should be able to tell by valve stem if they tubeless or tube type. Most new tires are tubeless
   / Slow leaking tire with rim guard. #3
Should be tubeless. Plugging them are easy. After identifying where the leak is, rotate the tire so the leak is on top.
Thanks for the information. I can't tell by the valve stems other than they are not like on my Masseys many of which had cloride in that once.
I think I must have ran over a thorn.
:D Al
   / Slow leaking tire with rim guard. #5
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRK (A51406)
2014 INTERNATIONAL...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
