Slower Speed Stump Grinder question
   / Slower Speed Stump Grinder question #11
Carl- I only meant to pass on the 'math'!! The tip speed (I think) is critical. The units that I'm shadowing, seem to like about 5,000 feet per minute. With your 1000rpm Hydro unit a with a 20" wheel would be 5233' per minute. Right in the ball park!! ~S
   / Slower Speed Stump Grinder question #12
Surplus Center is their web name. They've always been Burden Sales when you see the bill. Read their "about us" page. Very old business.
Hi Nostep, Is that a Magnatrac mini-dozer in your avatar? I have an M-1800 with a 16 hp motor. I am looking to sell mine.
   / Slower Speed Stump Grinder question #13
Carl,
Are there any stump grinder dealers in your area? If so, you might be able to purchase the hydraulic head unit from one of the units that will match your GPM and pressure, or find a used one. If you have to make it your self, you will have to do a bit of machining, and then you will have to set up the teeth at the correct angle, and spacing. Although a machine shop can do all this, they aren't cheap. There are a lot of different teeth out there.
You probably know that I have the PT stump grinder/trencher, but I am planning to mount it differently so it will cut/grind left to right. not back at me. I also have a tow behind small stump grinder that uses a Honda 13 HP engine to double belt drive the cutting fead which is about 12 in in diameter, with eight carbide teeth. Although it has fewer teeth, the head turns about 2000 RPM, and it does a credible job. The teeth are only a couple of dollars apiece.
2003 Big Tex 10PI...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
2007 Ford F-350 9ft. Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2021 John Deere HPX815E Gator 4x4 Utility Cart (A56857)
2021 John Deere...
