Slush worse than bale twine
   / Slush worse than bale twine #11
Slush like that will jam and plug any snowblower ever made. That said, keep the RPM as high possible and blowing at a higher through put will increase the time between jams.
Solid augers like on your blower will jam worse than hollow augers but hollow augers will still jam.
A side chute rotating drum blower is about the only blower that will not plug up with slush.
   / Slush worse than bale twine #12
From what your picture shows - you don't have much slush or snow to worry about anyhow. Twenty eight years using a 3-point blower here. Wet snow just does not blow well. Slush - I won't even try with the blower. It will freeze up in the blower, while you are running, and blow a shear bolt.
If it gets cold - you might stand a chance. BUT - watch out - all that slush will turn to ice and "something" is bound to break if you try to use the blower on frozen slush.
Best to move slush with a front mount plow or a 3-point rear blade.
TANK MANIFOLD (A55745)
HEADERS & ENGINE MOUNTS FOR V8 ENGINE SWAP (A58376)
HEADERS & ENGINE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
1972 Chevrolet Cheyenne 10 4x4 Pickup (A57453)
1972 Chevrolet...
Ratchet Straps (A59230)
Ratchet Straps...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
