Small barn plans / suggestions
   / Small barn plans / suggestions #11
Just2quickz28 said:
The slab is thick in the center, I drilled a hole with the longest masonary bit I had at the house for the hammer drill and the slab is over 7 inches in the center. As far as being a swamp, this is New England where frost heave is a real issue that is probably why the piers are there. I know here in Rhode Island that even piers for decks need to be in at least 48 inches in the ground.
The frost heave would not be an issue with a slab on grade, it is designed to float on top of the ground and move with the frost, like a patio slab, or driveway does. This can work just fine for shed or garage that is not attached to another building. I have only seen the piers used with it, in my area, when the ground was soft/wet.
It is possible, & likely that your local codes require more. But, I doubt they require concrete over 7" thick, through out a slab that size.
Do you know if the previous owner was an engineer?
   / Small barn plans / suggestions #12
10'x15' slab looks to me like a good start for a feed room/tack room. It can be implemented with your barn either on a wall or centered in the middle (don't laugh, I did see a tack room/office in the center of a horse barn). It can be insulated/heated/air conditioned, add water etc and it might for out for ya.
Eddie thanks for the advice.
I like this floor plan Barn Plans - StableWise Gallery
but I was thinking of making the stalls 12x12. As far as stick framing the building around here that would require a frost wall all the way around the building min. 48inches deep with the slab in the middle that adds a lot more to the cost of the excavation. I do like the placement of the barn though there are a few other locations I could look into. Mostly this site was the pick because it was the high point of the land which all slopes down in one direction. I will have to get some better pictures of what I am dealing with.
ray66v
I dont know much about the previous owners the house was a foreclosure. But that slab is pure over kill.
I do have plenty of carpentry knowledge to work with. I worked construction to pay for college and just got done building a 10ft x20ft 2 floor addition on my parents house on an existing foundation. But horse barns and post and beam construction is new to me. I do understand the socket systems might not be a cost saving move, but the ability for me to do the rest of the work pretty much with out major equipment and what not would be great.
Pretty much I have narrowed it down to either use the socket systems if they will pass snuff with the building inspector or do a pole barn on a different location and tear out the concrete slab and re-work the layout for the paddocks and ring.
2020 KUBOTA RTV...
TIRE MOUNTING AIR MACHINE (A53843)
TIRE MOUNTING AIR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
