Small Briggs Engine help...
   / Small Briggs Engine help...
Sorry, just now came back to check the thread again.. it's better, but not "fixed." I'll try adjusting the screw slighlty when I mow again (if.. it's SOOOO dry here, but got 3/4" the other night) Should know this weekend...
   / Small Briggs Engine help... #12
Some darn good advice was given...soooo I'll give it a shot.
I had 19.5hp doing the samething and come to find out the choke wasn't opening all the way...after tractor warm up lack of rpm's to cut...spray some WD40 into cable no more problem.
Since you and your dad are having the same problem,just wondering if fuel being purchase from the same gas station...maybe try another gas station??
Well as Mr Murphy would have it... it's been BONE dry in Kansas all summer and it has rained for the last 3 days..... didn't so much as glance at the mower with all the wet stuff around....
   / Small Briggs Engine help... #14
Try this.
Take the air Filter off. Start the engine, and rev it to full throttle, and put your hand firmly over the intake, completely chokeing the engine.
This will create a strong Vaccum, and suck any crap through the jets.
It is not a Governor problem, the fact the governor is working proves that. What is happening is the Engine is running at say 3000 rpms, and it runs lean to the point it cant run any longer and start to slow, thusly, the governor opens the throttle, allowing the carb to draft stronger, and pull more fuel up, it recovers, and closes back down.
Typically, the jets are a little gummed, and causes it to run slightly lean, with todays CARB and EPA laws, they are lean from the factory, so there isnt alot of room to play with before it hunts.
If the governor wasnt working, the engine would run lean, then shut off.
If you run it slightly choked, does the hunting condition go away?
   / Small Briggs Engine help... #15
I ran a half a can of Seafoam carborator cleaner with a tank of gas and now the engine is only surging when the mowing deck is not engaged. The engine seems to run nicely during mowing. Thanks
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
Dump Truck Box with Tarp System (A51691)
Dump Truck Box...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
2019 BOBCAT S770 SKID STEER (A52705)
2019 BOBCAT S770...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Electric Mobility Scooter (A54815)
Electric Mobility...
