small bx2200 BIG piece of Concrete - HELP!!
   / small bx2200 BIG piece of Concrete - HELP!! #11
469 lbs - drill & bolt on some brackets -use on 3pt for FEL ballast block
   / small bx2200 BIG piece of Concrete - HELP!! #12
Your tractor can DRAG far more than it can lift. Gravity and the earth are your friends. If you try to cleanly lift a 800# piece of concrete, you must be able to LIFT the entire 800#. Hhowever, if you DRAG the same thing, you can get by with lifting one side or probably only 400# of weight. Angles and heights will change all this, but the basic thought is the same. Let 400# drag on the ground and only have to LIFT the other 400# Get one side 3-5" off the ground and you are good to go. If the bottom is very rough, flip it over to get a smoother skidding surface.
Think of a block and tackle combo. Once you double the line, you cut the lifting requiremnet in half. That is how a 125# weakling can lift 300# with a block and tackle with multiple lines.
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
Charlotte County (A50323)
Charlotte County...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
