Small heavy duty trailer
   / Small heavy duty trailer #21
My suggestion would be a 6x20 flat bed behind a 3/4 ton truck. Then pull the civic and a 4x4 trailer both onto the flat bed and tow it that way. Not to be snide, but personally I think using that civic to tow regularly will negate everything you ever read about a Honda's reliability.
When they rate that Honda for 1000, that INCLUDES the receiver and hitch, so that leaves about 900lbs for the trailer and payload. I bet that gas mileage goes from low 30's on the freeway, to about 12, with all that extra weight and wind drag. I will also be surprised if it will pull any hills at all in OD.
Haven't even gotten into braking on down hill grades.
I'd say it's time for a mini van for the wife.
If his wife has a 3-400# trailer with 300# of stuff in two totes, thats not going to be much different of a load on the car than 4 big guys in the car with a pod on the roof and a full trunk...
Aaron Z
   / Small heavy duty trailer #22
True, but when you load those guys in the car, AND the trailer......that's what usually happens.
From the OP's first post it seemed like it would be a regular thing. Civic's not really a tow vehicle to me, but to each their own.
Its a once per month or once every other month. Its doesn't make sense to be driving more card than we need. I drove a pickup as a daily driver for years. I know its rough to have too much vehicle.
But thanks for the suggestions guys!
   / Small heavy duty trailer #25
Those small trailers are easy to pull. The one I described above is now pulled by my BCS 2 wheel tractor. They are so light weight your car won't notice a thing, even with a couple hundred pounds on it.
   / Small heavy duty trailer #26
I use a Triton single place aluminum snowmobile trailer behind a Jetta Diesel. You don't know it's behind you except for the noise. It can be lifted with one hand when it is attached to the trailer ball. I don't think it weighs 200 pounds.
I say go for it, Fred
Triton Elite5 snowmobile trailer
   / Small heavy duty trailer #27
A 5' by 12' trailer that weighs 375# to carry a load that is 36" to 42" wide and 48" to 60" long?
Aaron Z
   / Small heavy duty trailer #28
It's long enough to handle nicely. How wide is a snowmobile? Can't remember I quit riding when I turned 100 years old.
Fred
   / Small heavy duty trailer #30
Get a H.F. trailer and don't worry. Tt is just what you need. Use it till the tires wear out(5-7 years). Sell it for what you paid for it, and buy another. They do take a few hours to put together because of the number of bolts, but it is not difficult. You also need to get a 4 x 8 sheet of waterproof plywood home for the trailer you don't have yet.
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2013 FREIGHTLINER M2 TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
198367 (A51243)
198367 (A51243)
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
