Small property b26 replacement suggestions?
   / Small property b26 replacement suggestions? #13
Thanks, looks good
   / Small property b26 replacement suggestions? #14
The t5 does have a higher lift capacity by about 400 lbs iirc, but I agree, the Terramite isn't nearly as versatile.
Honestly if I were to replace my tractor it would be with a B26, used of course, couldn't swing a new one.
An idea of prices for my area, there's a 900+hr clean one with hyd thumb and thr bh qa bucket for 25k, similar without the thumb and bh bucket qa seem to go for about 20-24k.
I really want that one with the thumb.......
   / Small property b26 replacement suggestions? #15
It should be simple to add a hydraulic thumb to a B26 since the brackets are already there. All you need is money for the thumb, cylinder, hoses and valves.
   / Small property b26 replacement suggestions? #16
3000 PSI won't hurt a thing on a TLB. One thing I don't like about the B26, & the Kubota TLB's in general is tiny front tires. Better if front end had more flotation.
   / Small property b26 replacement suggestions? #17
I have an acre and I have a BX25D. Sometimes I think a little bigger would be good but it's usually just because I want things done quicker and the extra capacity of a larger machine would do the job quicker. I wouldn't downsize what you have as the only benifit is a few extra 💵 in your pocket and you said you don't need the cash at the moment.
Looking at the photos inside your shed there ia way too much space so you need to fill that with all sorts of other stuff that you may (or may not) really need 👍🚜
   / Small property b26 replacement suggestions? #18
I purchased a b26 TLB used to finish a bunch of projects. It's a 2008 with 750 hrs. A little wear but runs awesome.
It was an expensive investment, and after my construction/excavation projects I think I want to sell it because they command a premium, I hate having so much cash tied up. ....
Problem is, it's so darn handy, I use quick attach forks a lot in addition to landscape and snow removal with the bucket.
(SNIP)
Or will I have remorse and I should just keep it?
Well......
Unless your muscles and joints are getting both younger and stronger I wouldn't risk having a new barn without having a mechanical hired hand to pick up and place things. All us old guys know how hard it is to find a new back.
Yep, taking a chance on remorse is always a risky bet. And it doesn't get any easier. I'm thinking that you need more info. Frankly, I'd go the other direction and see how adding a hydraulic thumb changes the perspective.
As for tying up money, a low hour b26 seems as good a conservative financial backstop as you are likely to find.
best,
rScotty
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
Genie GTH-644 (A50490)
74in FEL HD Round Back Bucket (A53472)
74in FEL HD Round...
LOT NUMBER 146 (A53084)
LOT NUMBER 146...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
