May 24, 2010 / Smallest tractor with grapple #1 kuboman Veteran Member Joined Dec 5, 2009 Messages 2,304 Location Canada Tractor B3200, L5740, Does anyone know the smallest available tractor from Kubota that has a Kubota grapple available for the loader? I have not had any luck finding a Kubota grapple.
May 24, 2010 / Smallest tractor with grapple #2 kennyd Advertiser Joined Jul 6, 2003 Messages 13,839 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 That is because Kubota does not make grapples, they are all aftermarket.
May 25, 2010 / Smallest tractor with grapple Thread Starter #3 OP kuboman Veteran Member Joined Dec 5, 2009 Messages 2,304 Location Canada Tractor B3200, L5740, Ok then does anyone know which models have a front hydraulic outlet and valve.
May 25, 2010 / Smallest tractor with grapple #4 B BruceWard Platinum Member Joined Sep 28, 2008 Messages 850 Location Central, AR Kubota sells kits to add remotes front or rear for most models. Or you can build your own.
May 25, 2010 / Smallest tractor with grapple #5 kennyd Advertiser Joined Jul 6, 2003 Messages 13,839 Location Westminster, MD Tractor John Deere 3720 CAB/TLB, JD455 BruceWard said: Kubota sells kits to add remotes front or rear for most models. Or you can build your own. Click to expand... Exactly. Most poeple on TBN add the front remotes themselves from aquired parts or "kits" from thier dealer or companies like WR Long. Search for these terms in the Hydraulics and Attachment forums for HOURS of reading: grapple remote 4n1 WR Long diverter 3rd function
May 25, 2010 / Smallest tractor with grapple #6 Volfandt Veteran Member Joined Sep 7, 2004 Messages 1,950 Location TN Tractor 2004 Kubota BX23, 1966 WheelHorse 856 You may find this thread very informative. http://www.tractorbynet.com/forums/kubota-owning-operating/66955-grapple-bx23.html
