Smithy 3in1 Mill/Drill/Lathe
   / Smithy 3in1 Mill/Drill/Lathe #11
There is a Yahoo group for Smithy machines run by a machinist who owns one but is not associated with the company. Lots of good info and many impressive projects completed. Also they tolerate "rookie" questions very very well.
   / Smithy 3in1 Mill/Drill/Lathe #12
Have a link to the group?
   / Smithy 3in1 Mill/Drill/Lathe #13
You could Google "Yahoo groups Smithy machines" or click this link
Yahoo! Groups
Lots of really knowledgeable machining people that is not just related to Smithy or any other 3-in-1's.
   / Smithy 3in1 Mill/Drill/Lathe #14
I have one that looks identical but through a different company. Fun reading the poorly interpeted chinese manual. Anyway I have had it for at least 10 years and well over a 1000 hours. I like that it will drive the table (not at the same time) on both axis and used this to make heat sinks out of blocks of aluminum. It has a very large swing over the bed which is handy and would require a massive lathe to match. You will need a cast steel block option to raise the work high enough to use the Mill. I never did figure out the threading part of it with all the gear pieces etc. enjoy.
   / Smithy 3in1 Mill/Drill/Lathe #15
I've owned/used a Smithy Granite 1340 for about 6 years now. It is just about ideal for me. Sure larger, better, more costly & seperate machines would be even better, but for a reasonable price it does everything I've asked it to do. Mine easily holds .001 +/- tolerance. It is a little frustrating when the machine you need is not the one currently set-up, but switch over does not take more than a few minutes. It is advertised and sold as a "bench-top" machine so no, you can't turn and mill large items, but for the things it was designed to do it does them well. Size-wise I push mine to the limits and have to take it slowly, but it has handled it. I've been very pleased with mine!
   / Smithy 3in1 Mill/Drill/Lathe #16
My father hates his, and wishes he'd bit the bullet and gone with a reconditioned higher quality machine instead.
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
SHOPBUILT 40FT FLARE STACK (A52472)
SHOPBUILT 40FT...
