Snatchblock for PTO winch...
   / Snatchblock for PTO winch... #1
Coyote machine
Super Member
Southern VT
22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Seeking a snatch-block kit or just a good snatch-block for my PTO winch.
Anyone have any good sources or links to same?
Thanks in advance.
   / Snatchblock for PTO winch... #3
TSC has larger ones like come with the Champion 10K winch. Look in the trailer hitch / winch area rather than the cable / chain section of the store.
They are less than $40 if I remember correctly.
Thanks all for your replies/suggestions as to where to find a snatch block for my tractor.
Here is what I decided to get and why:
Snatch Block N1002
As can be seen at their site, (as shown in their videos) the Lewis winch snatch block allows one to open the block to allow the cable in, as well it allows the tree saver strap to attach WITHOUT having to take the block completely apart. I purchased the larger block even though I was drawn to the smaller one but decided the larger would handle any load my Igland 4001 winch threw at it. I did not want to chance having the winch overpower the block and possibly fail.
I like the strap they sell too because it has an end that is designed to attach to the block and it will not damage the tree it is attached to.
To my fellow Vermonter who replied; I had just bought a block at TSC in Rutland before you replied, but was hoping to find something more like I described above. Where do you hail from? ( I'm in that store all the time picking up odds and ends for around the farm/home):laughing:
   / Snatchblock for PTO winch... #7
CM -- I live up in Stowe, but never pass an opportunity to ride my GS to pick up small items. My wife once sent me out for a loaf of bread, which I bought in Saranac Lake, NY.
Any excuse for a ride...
Pete
   / Snatchblock for PTO winch... #8
I try to buy this kind of stuff from rigging stores in large towns, last one I purchased was in Las Vegas, NV. I prefer something like McKissock (spelling) easy to open large enough spool so as not to damage the wire or rope.
I would be leary of a TSC block as it might become a missle.:eek:
   / Snatchblock for PTO winch... #9
I got one of these from Surplus Center:
4 TON SNATCH BLOCK
Item# 3-1021-4
13
$12.95 Go
8 TON SNATCH BLOCK
Item# 3-1021-8
19
$24.95
   / Snatchblock for PTO winch... #10
Now that you already picked one up never mind. But you did right in getting one that opens up without having to thread cable or rope through. Baileysonline is a good source. I use 10-20 thousand pound rated blocks. Keep an eye on frayed cables and ropes as your weak links. Tree savers are a good idea as you have done. Then if you use carabiners or clevis bolts make sure they are rated high enough. Locking steel carabiners not aluminum latching.....
2003 MERCEDES-BENZ CLK-Class. w e we p (A50324)
2003 MERCEDES-BENZ...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
2002 KOST MH (A50324)
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
