Snow Snow Blower Casters for Gravel Road - Photos
   / Snow Blower Casters for Gravel Road - Photos
CASTER UPDATE:
Having used the snow blower with the casters every day since December 26 (lots of snow) I have found that the particular wheels are not up to the job. I would say they have 10 hours on them and have lost the shields on all four wheel ball bearings. This will surely cause early bearing failure. Additionally, one wheel lost one of the four bolts that hold the two halves of the wheel together. I found all seven other bolts loose.
If anyone knows of a supplier of high-quality 10" pneumatic caster wheels, with sealed bearings, I'm in the market.
The setup is working great, and once I found the correct clearance (about 1.5 inches scraper-to-ground for my gravel driveway) it now picks up no gravel, and breaks no shear pins.
SHEAR PIN REALIZATION and QUESTION:
On the subject auger shear pin alignment, it just recently occurred to me that I can easily find the broken pin by aligning the free auger side with the other auger side. Getting close by lining up the auger halves and then using a Q-tip to clear the grease makes it much easier to punch out the pin from the shaft. I am probably the only person who had not noticed this easy broken pin finding method!
I made up my own shear pins from 2.5" long 5/16" bolts by chucking them in the drill press and running a sidewinder grinder against the bolt where they should shear. They work fine but it's tough to judge how much to remove, and they usually turn out thinner than I'd like. Lacking a lathe, has anyone found a quick and precise way to cut the reliefs in standard bolts?
BS
   / Snow Blower Casters for Gravel Road - Photos #12
</font><font color="blue" class="small">( Lacking a lathe, has anyone found a quick and precise way to cut the reliefs in standard bolts? )</font>
If you have an X/Y drill press vise pick up a cutting bit and holder from some place like Enco and chuck it up in the vise - probably about $10 or so. Use the vise to feed the bit into the spinning bolt.
   / Snow Blower Casters for Gravel Road - Photos #13
just checking in to see if you had any other problems with your caster set-up. I am in the process of building a similar set-up for my snowblower so any tips would be helpful.
Hi,
No, I have had no more problems. The setup has really made the snow blower lots better.
If you find a good caster, please tell us how it works, and post some pictures of your setup.
-BS
   / Snow Blower Casters for Gravel Road - Photos #15
Well I will finally get to try my caster set-up out this weekend. They are forcasting @12" of snow. I used 10" casters from Grizzly tool company. I doubt if they are any better then what you are currently using though. I will try to get some photos this weekend to post of my casters.
   / Snow Blower Casters for Gravel Road - Photos #16
well I didnt get any pics of my caster set-up this weekend. Sorry. They worked pretty good though they keep the blower about 2" above the gravel. I ran into a problem with shear pins breaking (ALOT). They appear to be breaking from the little bit of gravel that is sucked up with the snow. Ever had this problem. Any ideas on what to do to solve it?
   / Snow Blower Casters for Gravel Road - Photos #17
Re: Snow Blower Casters for Gravel Road - Photos *DELETED*
Post deleted by Drtumolo
   / Snow Blower Casters for Gravel Road - Photos #18
I am unable to see this picture ..... it is all white space and very large. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
   / Snow Blower Casters for Gravel Road - Photos #19
Here is a picture of my caster set-up.
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2022 John Deere 8R 340 MFWD Tractor (A53342)
2022 John Deere 8R...
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51246)
2012 CATERPILLAR...
2001 Dodge Ram Wagon 3500 Passenger Van (A51692)
2001 Dodge Ram...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
PALLET OF PORTABLE AC UNITS (A51248)
PALLET OF PORTABLE...
