snow blower on my john deere 425 lawn tractor stops when I back up
   / snow blower on my john deere 425 lawn tractor stops when I back up #11
you are probably right. I am going to try it in the morning. My cub cadet has a position on the ignition switch that bypasses this safety. thanks again for the heads up.
Your Cub is like my Craftsman 28HP rider, key switch has the PTO in reverse position. I had an older Cub without the reverse cut off safety.
   / snow blower on my john deere 425 lawn tractor stops when I back up #12
I see that on the prints. do I have to follow that proceedure everytime I back up? or does that keep the snowblower engaged until I shut it off with the switch?
You have to lift the PTO switch every time before you back up or jam something under the switch to keep it lifted.
that is true in pretty much all parts of life
   / snow blower on my john deere 425 lawn tractor stops when I back up #14
I've seen a clothespin tied to to piece of twine for said purpose....
   / snow blower on my john deere 425 lawn tractor stops when I back up #15
the front pto that drives the snow blower stops everytime I back up. is the a way to bypass that feature on a 425 lawn tractor
I had the same issue on my John Deere 345 GT. If you go onto You-Tube and state your issue - you should find 3 or 4 remedies whereby inserting a 4" long wire into the back of the switch that controls the PTO will bypass that feature.
   / snow blower on my john deere 425 lawn tractor stops when I back up #16
Try a wood door shim just cut a notch in it so it will slide
under the knob etc
willy
   / snow blower on my john deere 425 lawn tractor stops when I back up #17
I had the same problem with my JD 750 riding mower. Then I found the yellow "override" button.
   / snow blower on my john deere 425 lawn tractor stops when I back up #18
We used a wooden clothes pin to keep pto engaged on our 425.
   / snow blower on my john deere 425 lawn tractor stops when I back up #19
Mx540 has a switch on the right side. When mowing or blowing snow when I lift that switch and start backing the implement keeps working
23311 (A51694)
23311 (A51694)
2019 FORD TRANSIT VAN (A52576)
2019 FORD TRANSIT...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
2007 Ford F-350 9FT Stakebody Flatbed Truck (A55852)
2007 Ford F-350...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
Box of Transport Ratchet Straps (A55851)
Box of Transport...
