Snow Equipment Owning/Operating Snow chain questions
   / Snow chain questions #11
Chains will mark blacktop and concrete. Chains with studs (v-bar) will *damage* blacktop and concrete.
   / Snow chain questions #12
Buddy of mine has the 4 link type chains. As long as he makes no sharp turns, he hasn't marred his asphalt drive. But he did mar it before he learned how to operate with chains.
BTW, tirechains.com describes the 2 link (which I have) and 4 link as "road" chains as they ride better (that's a relative term!!) and less likely to damage asphalt or concrete.
So far, I'm leaning toward 2 link chains. I'm not too concerned about maring the public road but I think there may be a neighbor that I'll be doing and I believe they have a black top drive which I did not want to scar up with divets from studs. A few scratches are acceptable but not so many that they have to re-apply sealcoat every year due to the chain activity.
   / Snow chain questions #14
You should be OK...just watch any sharp turns (especially when backing up to turn around) that would cause pivoting about one rear tire.
BTW...those 2 link chains are very heavy. Unless your drive (and your neighbor's drive) are pretty steep, you can probably use the 4 link chains (cheaper and lighter).
Which ever you decide upon, don't wait until the snow season begins to order them...might not be available then (mine weren't...had to make do until about May).
   / Snow chain questions #15
Crazyal, if you went with a more aggressive chain, what did you get and how do you deal with your floor?
I have some old pieces of carpet I use. Since it's only a short distance it's easy to do. But I have driven across the cement on occasion and it really doesn't hurt it much.
   / Snow chain questions #16
I'm in the same boat. steep driveway with pavement. I've seen what vbars do to the surface and want to start using cables as a happy medium between traction and surface damage. Does anyone know where a guy can get tire cables for rear tires on a compact tractor? I have a JD 3520 and there is very limited clearance between the tire and fender and cables would help with clearance issues.
   / Snow chain questions #17
I have operated with loaded tires and 2 link studded chains for about 5 years now.
B4 that thw chains were 4 link 'til I added the extra crosses.
When they were in the wide spacing I did create a few scrapes in the pave but since adding the extra cross links that happens not.
My experience is that the tire could skid a bit between link contacts, i.e. skip/grab, skid/grab but with thw 2 link setup there is always chain ground contact ergo no skidding.
Also the ride is much more tolerable. With the wide 4 link gap you felt kinda like you were riding a horse rather than driving a vehicle on wheels.
As to marking the pavement or concrete, maybe a bit but then It is a drive and not my living room floor and spring thaw along with the debris/dirt will soon hide any scratches, but then I don't wax my tractor either.
   / Snow chain questions #18
I have a M F 184 4- wheel drive with an 11' snow blade. We get alot of snow and have had as much as 26' ,thats feet total for the year, last winter. I run tire chains on all 4 tires. my shop floor is concrete I have damaged this floor and had to have it repairedby just one trip into the shop. Now I put plywood down everytime I need to put the 184 in the shop. So beware. I use V bar chains as my driveway is nearly 1 mile long and very steep.
Thanks everyone, colletively, your insight(s) have been extremely helpful. Score another :thumbsup: for the TBN community.
I'll be ordering the 2 link ladder style for my L3700SU; as soon as I can prove that they will fit under the fenders. The inside of the tire is only 1.5 inches from the fender and rops mount.
I'll go over to my neighbor's house and throw on his chains and see if they'll fit without hitting the fender & mount frame.
   / Snow chain questions #20
I think you'll need more clearance (2.5" or so)...might have to reverse your wheels or swap side to side.
2013 Jeep Grand Cherokee Laredo SUV (A55853)
2013 Jeep Grand...
2003 CATERPILLAR M316C MOBILE EXCAVATOR (A52707)
2003 CATERPILLAR...
UNUSED FUTURE LS43 HYD WOOD SPLITTER (A57193)
UNUSED FUTURE LS43...
2020 Ford Explorer AWD SUV (A55853)
2020 Ford Explorer...
1354 (A57192)
1354 (A57192)
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
