OK PILOON, point well taken . the intermediate shaft idea was simply what I saw on the SnoVac site. simple is better for sure so if I don't need a third shaft then so much the better. I appreciate your comments . thanks!
Sure you could use an intermediate shaft but then you'd have 2 chains and 4 sprockets plus bearings and shafts and some structure.
Also add 2 adjusters.
You are blowing snow which is frozen water and when wet belts will want to slip.(and no matter how you build, snow will fly)
When I rigged my setup I mounted the motor on top of my blower with shaft sprocket lined up with the blower input shaft.
When the PTO shaft removed my blower had a short keyed shaft sticking out ready to accept the large driven sprocket.
I venture to say that all blowers will have a similar short keyed shaft setup as that is how the PTO shaft has to couple.
Brief shopping and you will find that any diam shaft combined with diam sprocket is available in different chain sizes.
Your driven sprocket can in fact be almost as large as the blower impeller and still clear.
As a tensioner you need a 3rd idler small sprocket on a pivot that you add pressure or tension to the slack side of the chain.
I think the chain generally used is # 40 but could be wrong..
Naturally the idler needs to run on bearings and a method devised to adjust.(hinged with longish screw)
I am sure belts could do the job but you'd probably need double or triple belts to handle the HP.
