Snowblower Chute : open vs partially closed
   / Snowblower Chute : open vs partially closed
The Mckee snow clearer you have has a series of piano hinge segments to control the arc
of the chute and spout to dispose of the snow.
QUOTE]
The chute on my blower only has one hinge.
   / Snowblower Chute : open vs partially closed #12
more use this winter so far than the previous 2 winters combined. So glad I built the cab.
I just ordered a soft cab.. be delivered tomorrow!
   / Snowblower Chute : open vs partially closed #13
My self powered blower is also a McKee "Blizzard".
A Mennonite who builds equipment (and snow blowers) told me the secret. The chute should be in a V configuration. So when there is only little snow, it all rides down in the V together in a narrow stream. When there is more, the V simply fills up.
You can accomplish this by welding in some appropriately formed sheet metal.
I think the round chutes work better, because this is kind of what happens anyway. The good news is that the V is easy to make in a square style chute.
   / Snowblower Chute : open vs partially closed #14
QUOTE]
What I ment was the chute has sections that are cut and bent
in place which makes it look like it had multiple hinges.
   / Snowblower Chute : open vs partially closed #15
You have a McKee 720 if I am not mistaken. Had one for years behind a yery heavy 2wd Nuffield 465.
The hitch pins on the blower would bend from the offset push from the tractor arms so I modified the blower to have the 3 pt arms go between two heavy plates with a pin connecting the blower to the 3 pt arms.
This picture was taken after I sold it and it had rusted considerably since I owned it.
McKee blowers had fans that were too small. The fan could not keep up to the augers rate of feeding the snow to it.
On my Nuffield, the reverse speed was too fast so I imported and installed a special low reverse gear and still the blower could not keep up to the tractor backing into the snow.
John Deere sold the same blower just painted green and can be a source of parts for you.
McKee has been out of business for years.
If you compare the fan diameter and # of blades with more modern blowers you will find larger fans on newer blowers.
With minimal snow, there is a large circulation of air into the fan, out the chute and back into the fan. That is why the snow fog hangs around. Shut the pto off and back up until the blower is almost full and then start the blower up. This will minimize the snow fog.
Sorry if this is not the encouraging opinion any owner of a piece of equipment likes to hear but it is best to recognize its basic limitations so you dont spend a lot of time only to still be frustrated with it's performance.
Everything is relative so having a McKee is a big step up from using a blade or FEL bucket.
Dave M7040
JNC 1224 Jump Box with Charger (A54865)
JNC 1224 Jump Box...
2016 Ford Explorer 4WD SUV (A55758)
2016 Ford Explorer...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2016 Nissan Frontier Ext. Cab Pickup Truck (A55788)
2016 Nissan...
2011 Ford F-250 Ext. Cab Reading Service Truck (A55788)
2011 Ford F-250...
