Snowblower chute slow in one direction
   / Snowblower chute slow in one direction #1
SEJones720
none yet
I have a Kioti DK4210HSE. My snowblower chute rotates normally to the left but is very slow to the right. This problem began right after I had removed the caps on joystick valve assembly to clean and fill with grease to repair my float which had become difficult to disengage. Any suggestions would be appreciated. Definitely a Newbie! Thanks!
   / Snowblower chute slow in one direction #2
Is the chute rotation tied into the front loader hydraulic circuit?
   / Snowblower chute slow in one direction #6
If that's not it, a lot of times the bucket curl circuit has a regen feature on the dump side. You would feel a "hard spot" when pushing the lever to the right and when you push past it the rotation would slow down.
Thanks, everyone! I disconnected and cleaned the hydraulic lines and that did the trick! This was my first posted questions, but you guys have helped me many times with my tractor over the last few years. Thanks a bunch!
   / Snowblower chute slow in one direction #8
Thanks for letting us know!
   / Snowblower chute slow in one direction #9
Glad it was easy fix. :)
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
