Snowblower chute slow in one direction
   / Snowblower chute slow in one direction #1
SEJones720
none yet
I have a Kioti DK4210HSE. My snowblower chute rotates normally to the left but is very slow to the right. This problem began right after I had removed the caps on joystick valve assembly to clean and fill with grease to repair my float which had become difficult to disengage. Any suggestions would be appreciated. Definitely a Newbie! Thanks!
   / Snowblower chute slow in one direction #2
Is the chute rotation tied into the front loader hydraulic circuit?
   / Snowblower chute slow in one direction #6
If that's not it, a lot of times the bucket curl circuit has a regen feature on the dump side. You would feel a "hard spot" when pushing the lever to the right and when you push past it the rotation would slow down.
Thanks, everyone! I disconnected and cleaned the hydraulic lines and that did the trick! This was my first posted questions, but you guys have helped me many times with my tractor over the last few years. Thanks a bunch!
   / Snowblower chute slow in one direction #8
Thanks for letting us know!
   / Snowblower chute slow in one direction #9
Glad it was easy fix. :)
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
1000 Gallon Propane Burner (A53316)
1000 Gallon...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
2018 John Deere 325G (A47477)
2018 John Deere...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
