Snowblower Snowblower for Front End Loaders?
   / Snowblower for Front End Loaders? #11
I made an attachment that I mounted on the bucket of my old Oliver OC3. Unfortunately I don't have any pictures but it was a blower with a small 4 cylinder gas auto engine that drove the blower. With a little experimenting I found the proper speed to run the engine, and just mounted it on a metal plate welded to the blower. It was far from beautiful but it worked well. It went when I sold the Oliver.
Charles, that's just what my number one plan is. As you say, the M59 will probably run a snowblower fine just as it is. I guess I could rent a blower from one of the skidsteer outfits and give it a try, but knowing myself I'll probably just buy a used one when it comes up.
I absolutely agree on the M59 not getting enough press. It continues to amaze me and it also amazes my buddies with their big Case TBLs. But the M59 is in sort of an odd category because Kubota isn't known for their construction equipment...or at least I haven't much. The JD TBL is the only thing close, but it is just a bit smaller and not so many features. Nice machine, though....I like those too.
Another option that someone mentioned is to just buy a snowblower that has an automotive engine mounted right on it for power. Then slide the whole kit into that huge 7' bucket on the M59, chain it down, and off we go to throw some snow. With the load-handling capacity of the M59, that isn't as crazy as it sounds.
rScotty
One of the big selling points of the m59 to my mind, that doesn't get enough press, is that you can run it like a big, stable comfortable skidsteer. I often do, and its something I don't think any other tractor can do.
   / Snowblower for Front End Loaders? #13
well, not so much that the m59 doesn't get press in general, but that people don't realize what a useful rough terrain skidsteer substitute it is.
engine in bucket would lift fine, but seems like a lot more hassle. Just saw a 74" snowblower for a skidsteer on craigslist for 2k - that'd just take 30 seconds to hook on with the QA and front remotes and away you go. Renting one would be great - that would show whether it worked. But I'd be shocked if it didn't.
one thing - I find running hydro motors on the front works best if I run full throttle - 2900 or so.
   / Snowblower for Front End Loaders? #14
Just use a standard flow skidteer blower. Your 16 gpm at 2800 psi is going to give you @ 25hp to run the blower. Couple switches and a plug by the couplers and your good to go.
A bobcat 773 is 16.9 at 3000 and runs a blower fine.
The only downside to renting or picking up a used one is that we have 5 different fan motors volumes we use for machines with flow rates between 13 and 24 gpm, to tune our blowers within our standard flow blower line. This tuning allow us to keep fan rpm close to ideal.
So if you buy a used blower try to find one that was set up for a machine with simular flow
Erskine now also offers pto driven hydraulic power packs to run skidsteer blowers if your tractor does not have the flow to run a blower in 15 20 and 24gpm.
Ken
   / Snowblower for Front End Loaders? #15
Thats interesting on the fans ken, thanks, didn't know that.
If I bought one new I'd play it safe and get it for 13 gpm probably - nice to have a margin.
   / Snowblower for Front End Loaders? #16
Specing a motor for a lower flow would result in running the fan at a higher rpm while running the engine at the rpm it was spec'd 16 gpm at, but with less torque.
So in theory it would throw snow farther but the sytem would go to maximum or relief pressure with a lighter load. Then the fans rpm would drop quickly making it easier to stall out.
It may also shorten the motors life if it is not spec'd for the volume it is actually receiving and you hydraulic pump would see more time at higher pressures.
The only way I would recomend this is if you're certain you don't want to run your engine above a certain rpm and therefore would not be pumping over 13 gpm. As a result you would be giving up potential hp for the blower.
16 gpm at 2800 psi is 31 hp but 13 gpm at 2800 psi is only 25 hp. That is the max draw a pump of those sizes will put on your engine. Now if your tractorcould pump 40 gpm at 2800 psi then you would have up to 77 hp to put to a blower. This is where you here about hyd blowers needing big pumps. Bigger flow and or higher pressure will allow more engine power to go to the blower.
This is also where a pto blower has somewhat of an advantage, it has 100% of the engines power available, where most hydraulic pumps are not designed to draw everything the engine has. But at the same time you don't need all the power unless blowing conditions are tough, (also you need some power left to drive the tires) , and if they are too tough then you need to slow down which is when a hst transmission better lends itself to snow blowing too.
Hope that helps.
Ken
   / Snowblower for Front End Loaders? #17
yeah. I was thinking 13 would let you run it at lower rpm, and make up for the qc drag on flow - I have a feeling our 16 is theoretical, and 13 is a "safe" number, and would leave room for power to the wheels (m59 is HST)
Best of all would be if someone actually slapped a hydro flow meter on an m59 in low gear moving along at 2600 rpm or some such. That would be an interesting piece of data.
Tough thing is hydro flow meters cost a lot.
   / Snowblower for Front End Loaders? #18
If the 16 gpm is a spec, that machine should not have trouble making that volume, unless the pump is defective.
You still can run the engine slower if you like, it would just shorten the cast distance ofthe blower, (same a pto driven one)
Now a flow meter is the best way to prove the pump volume. Most local hydraulic shops have these for testing purposes, plumbing it into your front couplers and testing the volumes at various pressures should not take more then 30 minutes. The expense would be minimal if there is some question.
I see some for as little as $400 if mem serves.
We still always set a blower up for the max available flow. Running less flow will only reduce the performance, overflowing it can be expensive. The two hydraulic motors are @ 1600.00 alone.
Ken
   / Snowblower for Front End Loaders? #19
Now THAT is great info, case closed.
   / Snowblower for Front End Loaders? #20
Am wondering if you ever put that skid steer snow blower on the front of your M59.
We have an FFC 72" snow blower for 14-21GPM, and are considering purchasing the M59 TLB because it appears to be able to handle that level of blower. Would love to hear your input if you tried it out!
John
c. Massachusetts
rScotty
QA Hitch Plate (A56469)
QA Hitch Plate...
2005 EZ-GO Utility Cart (A55853)
2005 EZ-GO Utility...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
