Snowblower skids excessive wear?
   / Snowblower skids excessive wear? #11
Guys, I understand these are wearable items (skids and scraper bar) but I just thought this looked a little excessive wear for only about 30min of actual use. Doesn't seem like these will last very long. :(
I'll try playing w/ the skid shoes to see if I can get them to lay flatter to wear more evenly.
Also, I can't image needing to weld on a wearable surface to a brand new piece of equipment (especially one that costs so much).
Zick they are most likely just mild steel, but expensive to replace. You could (rather than welding) stop by your town/county roads dept. and see if they have an old cutting edge from one of their road snow plows that they'd give you. They are pre punched with holes that just might be close enough apart for you to drill a pair in your skid shoes to bolt them on. Most town's around me use carbide edges that are 5/8 or 3/4" thick. I would think you might get years out of a set. You would have to find some plow type bolts for a flush face to attach them with.
   / Snowblower skids excessive wear? #12
You know - I don't think they have worn that much at all. I think the skid shoes have been installed backwards. Unbolt them and turn them around or reverse sides. Install them so the thicker portion of the shoe is toward the front. When you do that - adjust them so they sit flat on a flat surface.
I think they are designed to have the thicker portion of the shoe toward the front. Looks to me that about all that has worn off so far is the paint.
   / Snowblower skids excessive wear? #13
I am not from snow country, so this may be a stupid comment (I am from South Texas). Do you run the snow blower in "float." It looks to me like you may be applying down pressure to the snow blower and applying too much weight (transferring weight from the front axle to the snow blower skid shoes) to the snow blower. Running a front mount snow blower in float may be a "no-no" but I am not sure. I would say flip the shoes and try it with the loader valve in float and see what happens.
   / Snowblower skids excessive wear? #14
Unfortunately - my search for pictures of skid shoes on other identical units has netted - zero. You CAN adjust the angle on the blower skid shoes by loosening the bolts, tipping the unit forward(place something under the back of the unit to hold it forward), tighten the bolts. Lift the rear about as much as it will roll forward when it use.
From what I found - looks like a new pair of skid shoes will cost around $45 to $50.
   / Snowblower skids excessive wear? #15
To the OP: If I was your neighbor, I'd make you a couple of these with my plasma cutter, welder and my pile of scrap steel.
Here's a tip... lots of Colleges (especially trades/community colleges) have welding shops that you could show this to the instructor, and they could get the students to make you a few of them for free. I work at one, and I could make you an exact copy of that with the equipment we have there. For all that matters, we could try different grades of steel to see which one wears better or worse. This is a very simple part to make if you have have a CNC plasma cutter and could make a great demo or project for the students. I know I asked once to have something made, and I wound up getting like 8 copies of it... had more than I would need in my lifetime of the machine.
   / Snowblower skids excessive wear? #16
Maybe you mentioned it.....Are you using the float position. If not you should, I think...
   / Snowblower skids excessive wear? #17
I have some Ar400 that we use to re-line trash truck floors, it makes very durable skid shoes and wear plates. Some sources for used AR plate is steel targets for higher powered firearms.
   / Snowblower skids excessive wear? #18
If you own a welder just build up the surface with some beads. You can even get some hardfacing rods if you have a stick welder. But I would wait until the it's worn down to the point where it's rubbing flat on the shoe. I know with my front mount blower there's no front adjustment. The carriage bolts fit pretty tight so without drilling out the round holes in the blower to over size them to give adjustment (which I wouldn't do) I don't think you'll find much adjustment. If your subframe is like mine then it was very tight when new but given a few years of use it now has some play so the shoes sit flat.
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A52577)
2005 INTERNATIONAL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
27031 (A51692)
27031 (A51692)
