Snowblower - too big?
   / Snowblower - too big? #11
I run a 7 ft Lucknow (about 1000 lbs) on an L5030HSTC, it works great with the hydrostatic. The only problem I have is on steep hills I sometimes can't push the blower up. Without the blower my tractor is about 6500 lb and I have a 300 lb blade in the front bucket. I don't have chains on though as I have to drive down paved roads all the time.
   / Snowblower - too big? #12
Another advantage of the wider blower is less tendancy for the front tires to drive over the unblown snow in a turn.
   / Snowblower - too big? #13
...... my driveway is 8-9ft. wide (but 1000' long)......
Well here's a shameless plug - at the moment I have an extra Erskine 6' front-mounted snowblower - the kind that drives from the rear pto. Snowblowing going forward is good for doing long driveways. I take my loader off for the winter - but I've never missed it because the blower will eat any snow pile.
My rear wheels are about 76" wide so I got another Erskine that's wider. PM me if interested - unit is in good shape. Take care, Dick B
   / Snowblower - too big? #14
Is that it in the pic?
   / Snowblower - too big? #15
Yes the blower is the one in the picture, taken a couple (+) years ago - so it has a few more scratches now. Back then I posted pics and hook-up information for the Erskine front-mount. Here's a link to the discussion. The L5450 in the pics has been replaced by a newer one with a cab like my avatar. Take care, Dick B
   / Snowblower - too big? #16
I ran a 6' rear mount on my TZ25DA, 22hp at the pto. I never did make it bog, it was like nothing was there. BUT, I did have to run front weights because I didn't have a bucket and was using turf tires without chains.
If I'd have had chains, it would've been perfect. the 1300lb tractor just didn't push the best.
With traction, I could've run a bigger blower.
   / Snowblower - too big? #17
.......With traction, I could've run a bigger blower.
I agree - traction is often the weak link - power is important provided it can get to the ground.
I'm off for a few days - improving my own traction.
   / Snowblower - too big? #18
Don't post here much, but this thread did get my attention.
After spending the '08/'09 winter doing an OK job plowing with a rear grading blade I wanted to get away from snowbanks and blow it into the woods (an unpaved private road about 1/2 mile long)
For this past winter I went with a 68" Meteor PTO blower and it did a great job (for the "winter" we had). The rear tires are just over 60" wide so they run in the cleared road. My 4wd NH is geared and I run reverse in mid-range.
I only have about 23 PTO hp but it ran great- you should have no problem with more muscle at your PTO.
I agree with the poster who mentioned about not being able to go up a moderate hill, even with rear double ring chains on loaded tires. It is marginally better if I can get a front bucket full of wet snow. So I end up blowing that section downhill only.
Good luck,
John
Now if I can just stop throwing rocks......
   / Snowblower - too big? #19
Looks interesting but it seeems very rigid. Does it have any capability to move up and down over changing terrain?
   / Snowblower - too big? #20
Looks interesting but it seems very rigid. Does it have any capability to move up and down over changing terrain?
That was my concern too - about keeping good ground contact. But in fact it is quite flexible. The blower head has hydraulic up and down with float, and can pivot to follow the ground contour - works well I think..
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A57024)
Gleaner N630 Corn...
2013 Chevrolet Silverado 3500 Ext. Cab Animal Control Service Truck (A55852)
2013 Chevrolet...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
