Snowblower Snowblower trade?
   / Snowblower trade? #11
I have a new Allied 5 ft. snowblower never used if you would like to trade.
I'm in Scranton, Pa , about a two ride if you'll interested.
It's for a 3 pt. hitch.
   / Snowblower trade?
Von;
okay...let me know re: compatability. Since what I saw on the Kubota web site shows that it's not compatible, it would be up to you to determine if you're comfortable that it is.
I took some shots this morning of the components...let's see if they work.
This shot is of all the components lined up as they would be if it were on the tractor
   / Snowblower trade?
That first picture got the bottom cut off when I tried to resize it to up load it.
I'll try with a picture of the extendable PTO shaft (which is what got cut off in the first picture) - this connects to the tractor mid PTO and the PTO on the snowblower hardware.
   / Snowblower trade?
That worked...
This is the piece of snowblower hardware that gets bolted to the tractor and on which the snowblower itself gets hooked up. You can see the PTO connection that is on it
   / Snowblower trade?
This is the back of the blower itself that shows where the hookups are as well as the PTO shaft coming off of the blower that hooks into the PTO that is on the blower hardware
   / Snowblower trade?
Hydraulic cylinder - moves blower up and down about 4" - no side to side (ie: no angling)
   / Snowblower trade?
This is the front of the hardware that gets bolted onto the tractor - you're looking at it as though you are standing in front of the tractor. The four bolts you see are the bolts that hold it onto the tractor
   / Snowblower trade?
Last one...I lifted the hardware onto the blower to try and show where the two pin connects are - the blower has two prongs that slide into the bottom of the bracket that have a hitch pin to keep it in place. The cylinder similary has a hitch pin connection connecting it to the top of the hardware
   / Snowblower trade?
Trice1,
I'll have to wait and see if Von wants it, as he was first in line, so to speak.
Thanks
   / Snowblower trade? #20
Snowman,
The photos show me alot! It looks like it should fit! Let me check at the dealers tomorrow and make sure and I will get back to you in the afternoon! I'm sure I can make it fit! Heck thats what they make welders for!
Thanks, Von
UNUSED JCT 40' CONTAINER (A51244)
UNUSED JCT 40'...
2020 INTERNATIONAL LT625 DAY CAB (A52576)
2020 INTERNATIONAL...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
20 Yard Rolloff Container (A51573)
20 Yard Rolloff...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
