Snowblowers, and Garden Tractors??
   / Snowblowers, and Garden Tractors??
Thanks for all the great input here...... it's just what I was looking for. My garden tractor is a Simplicity Legacy that has both limited slip, and a locking differential, but is two wheel drive. The tractor is in the same weight range as a Jd x585.
   / Snowblowers, and Garden Tractors?? #12
My biggest problem with a blower on a garden tractor is my hands and toes get cold and drive back in to the garage to get warmed up before the job is done. I used to have a 32 inch self propeled and at least I stayed warm walking behind it.
   / Snowblowers, and Garden Tractors?? #13
My Murray was a 2wd without locking diff. While it is true that without the chains (and I presume weights) it was frustrating at best, I had no complaints with the chains installed and it was way, way faster than the dedicated units could dream of being. For the cold, I just wore snowpants and insulated boots.
   / Snowblowers, and Garden Tractors?? #14
Just about ANY machine beats shoveling by a LOOOONNNNG ways. A snowblower on a typical 2WD lawn tractor with some extra weight and tire chains will clear snow. The typical 2WD garden tractor will do better because of it's heavier weight and more robust tranny. A walk behind will work well if the area isn't too large and it fit's the operator's height. I'm 6'-3" and have to stoop over for most walk behind snowblowers and mowers. That strain on my bad back will put me out of commission in just a few minutes, so the ergonomics of the equipment should be considered. A lot of factors can come into play:
1. Size of area to be cleared?
2. Is surface paved or gravel?
3. Depth of average snow storm?
4. Depth of the exceptional snowstorm?
5. Average number of snow storms per season?
6. Operator's ability to lift, attach, push, shove equipment in the various options considered? Will spouse or child be required to operate this?
7. Is area to be cleared relatively flat? or sloped?
8. Will the equipment considered be able to clear the mess your local road dept. leaves at the end of the driveway?
9. Budget.... what best solves the above considerations and is still affordable?
   / Snowblowers, and Garden Tractors?? #15
With chains and weight you should be able to move /push a lot of snow with a front blade on this.
   / Snowblowers, and Garden Tractors?? #16
I have a JD Gt225 with a 42" thrower. I have no problems or complaints. It works excellent. I have chains, two wheel weights and four 40# weights on the weight bracket. My drivewau is tarred and mostly flat however. One of my brothers has a 2210 with a blower. His driveway is much steeper than mine, yet paved. He had to get chains because the FWA and turf tires didn't cut it.
   / Snowblowers, and Garden Tractors?? #17
I will say the best garden tractor for snow removal was my old 595 JD. I no longer own the machine, but it was a beast. I plowed drives on hillsides that most folks would not try. Among garden tractors, these machines have to be among the best out there. For sheer plowing and speed plowing, my Gator diesel was the ticket. It would plow at 10 mph and did a nice job to boot. I have had a plow for my JD 3720 which did great, but because the tractor is so much larger, it was not quite as fast as the Gator. To me the ultimate plowing ticket is an ATV or UTV with a front blade, followed closely by a JD X series or equivalent with a blower or blade.
John M
   / Snowblowers, and Garden Tractors?? #18
Chuck,
In my experiences, I've had pros & cons with both.
I started out with a Sears walk-behind snowblower that my mother had won in a raffle back in 1970. I then used a John Deere 212 garden tractor with a 12 hp Koehler engine and a 37" snowthrower. (A snowthrower uses a high-speed auger to "throw" the snow out of a chute. A snowblower uses a low-speed auger to push the snow into a high-speed impeller, which "blows" the snow out of a chute.)
The John Deere 212/snowthrower arrangement worked very well for over 15 years under all conditions. The only problems for me were installing the snow chains on the rear tires and installing the rear wheel weights. I eventually just left the wheel weights on but the snow chains were a constant chore for me to put on every winter. The other lesser problem was getting the mower deck/snowthrower on & off every season. It was still a far cry from running a walk behind snowblower.
By the way: If you are looking at lawn or garden tractors and wondering which is which, look at the rear wheels. If the rear wheels have lug nuts, it's probably a garden tractor. If the rear wheels have a single nut holding the rear tire rims on the axles, it's probably a lawn tractor. Garden tractors are more rugged, typically have heavier frames, larger engines, electric or hydraulic lift and a more robust transmission. Garden tractors are more suited to snowblowing and tilling. Garden tractors are better equipped for extra implements than lawn tractors, although many lawn tractors can handle snowblowing tasks very well.
Any way I looked at it, the 48" mower deck, snowthrower & tiller implements were heavy, cumbersome, labor intensive and sometimes injurious to my fingers and knuckles. After I changed implements, I had to reconfigure the correct drivebelt/pulley arrangements for each implement. However, they were good for their time.
Then there's storage: Keeping the snowthrower properly stored during the summer & vice versa for the mower deck. If you have a garage or a large enough storage shed, that's usually not a problem. Same thing for a walk-behind snowblower. I recommend a level concrete surface from which to change implements.
Three years ago, I purchased a new John Deere X595 garden tractor with 4 wheel drive. Things have really come a long way. The implements on this tractor are driven by shafts, not belts, and I have hydraulic lifting; no more "armstrong" techniques hauling back on a lever to lift up the mower deck, snowthrower and tiller.
The implements are easier to attach and change, even though the weight of the implements are more than my older equipment. The big plus is no more snow chains, weights and skinned knuckles. The HST transmission on the X595 makes speed/direction changes effortless without shifting and changing gears. Power steering with the 42" snowblower hanging off the front of the tractor is a big plus. The hydraulics have a "float" feature that allows the snowblower to glide over uneven terrain without scalping the surface being cleaned if it isn't asphalt or concrete.
I've done both & I'd rather use the garden tractor with various implements rather than specialized equipment for each task. It seems that you are leaning towards a garden tractor & snowblower/thrower arrangement. Keep in mind ease of implement interchangeability, maintenance, belt/shaft drive features, manual or electric/hydraulic lift features, ruggedness/durability and service/parts availability. In other words, get something even your wife or kids would like to use.
Hope this helps & good luck.
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2014 John Deere 244J (A47477)
2014 John Deere...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
STEEL WHEELS AND TIRES (A53843)
STEEL WHEELS AND...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
