Snowblower Snowblowers on dirt driveways
   / Snowblowers on dirt driveways #1
rico304
Cumberland County, Maine
JD 4300 w/ FEL
I'm sure it is in here somewhere, but I couldn't find it in a search. Can I use a snowblower attachment on a tractor to snowblow my 250' dirt driveway? I've read both things. Rocks break sheer pin....to....Works great. /forums/images/graemlins/confused.gif
Anyone use one on a dirt driveway? Thanks in advance! /forums/images/graemlins/grin.gif
   / Snowblowers on dirt driveways #2
They work fantastic. Just keep it about 3/4" to a 1" off the ground and start blowing.You might pick up a small stone here or there but if your shoots aming in a safe direction you should be ok. once the ground freezes even better. I used one on a all #2 stone drive about 150' long for about 5 years and not one problem. Just keep it off the ground a little. Mine was always used on stone so I welded a shim on the bottom that kept it up a little. I say go for it you'll love it.
Thanks jjcc246! I was hoping to hear from someone that used one in your situation. Thank you very much for reply!
   / Snowblowers on dirt driveways #4
I'll second what jjcc246 said. I've used three different snowblowers on our 700 foot gravel driveway and have thrown thousands of stones, some pretty big, with almost no effect on the blower. Up here in northern Michigan, once we get a nice hard packed layer of snow over the gravel, we don't see any more stones until spring. And then we get to rake up all the ones we threw in the winter. /forums/images/graemlins/frown.gif
Tom
TMcD_in_MI, appreciate the reply. I was told that you can't really use them on dirt driveways. Kinda bummed me out. I was hoping to hear from people that have used them on dirt to get their input. Hope more people post their experiences.
Thanks again!
   / Snowblowers on dirt driveways #6
I have a Blizzard B64 that I use on a 600' dirt drive with no problems at all. Adjust the skid shoes so it's up an inch or so and it works great.
   / Snowblowers on dirt driveways #7
I use one all the time on a gravel road and several driveways that are made of crusher run gravel. Like others have said, set your shoes high enough to get at least an inch of clearance. As winter goes on and things harden up, just lengthen out your top link to drop the cutting edge closer to the ground if you want. My Woods SS52 came with a grade 8 shear pin in the drive shaft, should have been a grade 5, I run grade 2 and keep a few in the tool box. They are cheap and easy to replace, I would rather do that than blow out something else in the drivetrain.
The obvious advantage with the blower is you only need to clear what you want open, no extra clearing to make room for the next storm like you do with a plow. Hit it once and its gone!
Brad
   / Snowblowers on dirt driveways #8
I agree with the recommendations above. In early winter, I use my backblade, turned backward and CAREFULLY push the snow off the driveway, driving in reverse. All the cautions about pushing on the 3PH apply, but I have found it works better than putting tracks into the snow like you would if you drove forward on it. Once the driveway has frozen, the blower works great if you follow the advice given here. Good luck!
   / Snowblowers on dirt driveways #9
If your plowing or snowblowing,its best if you can pack down the first amounts of snow in a dirt driveway,It gives you a nice frozen base ,so you dont pick up the rocks.If your blower has adjustable shoes,set them so you leave snow for the first couple times.If the blower is two stage ive seen very small rocks jam things up and break shear pins,its best to try to get a frozen base in my opinion.
ALAN
   / Snowblowers on dirt driveways #10
This is how I use my snow blower on my 300 foot driveway that is dirt, sand, gravel and a few patches of concrete. Using a snow blower on dirt and gravel works best if you set the shoes so the chute sets at least one inch above grade the first couple of times you use the snow blower and keep it high until the snow packs and ground freezes then it can be set lower until the snow melts and the ground softens with the thaw.
Farwell
2014 Honda Accord Sedan (A50324)
2014 Honda Accord...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
Tallman Water Pump (A50774)
Tallman Water Pump...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
DMI 13' Chisel Plow (A50515)
DMI 13' Chisel...
