SnowPlow Blade Flap
   / SnowPlow Blade Flap #1
swampy6
Foothills of The Adirondacks, New York State
Mahindra 4540 4WD
I'm looking to buy a snow deflector for the top of our snowplow, what's everyone using and where is the best place to buy one?
   / SnowPlow Blade Flap #2
I'd like to know also. I was thinking of going to Lowe's and see if they have some rubber like a shower pan liner or something like that, and bolt it on.
   / SnowPlow Blade Flap #4
I've used strips cut out of a thick rubber truck bed mat before and it worked well. Only lasted a few years out in the weather before it got cracked and would break around the fender washers on the bolts I had holding it on.
   / SnowPlow Blade Flap #5
Bon Jour Mon Ami,
Yes, used conveyor belts work very well it just takes time to install them with drilling the holes in the plow to mount the conveyor belt. You also need to have a length of strap iron drilled out to match the holes in the plow to mount them using fine thread hex head bolts, thick fender washers and nylock nuts to mount the lengths of conveyor belt.
If old conveyor belt is unavailable you can always use new round baler belt to do the same job mounting it using strap iron to hold the baler belt in place.
Another option would be slick sheet material from Horn Plastics. They have left over pieces for sale that can be bought in many thicknesses widths and lengths and you can mount them the same way. You will need to cut multiple pieces in longer lengths as a continuous piece will not sag over to act as a snow spray stopper.
The only way that used conveyor belt will work to your advantage is if it is a thin narrow width used conveyor belt as it will have more flex in it to hang down to act as a baffle. New cow stall mats and used thick conveyor belt will not do that for you but if you want a taller moldboard onn your snow plow will work well for you.
   / SnowPlow Blade Flap #6
Some of the pickup trucks (eg 2008 Ram) had a black plastic spoiler on the tailgate. People like me that bought caps for their trucks had to remove the spoiler. Last year I too saw I needed a upper rubber flap for my UTV 60 inch plow. I realized that this spoiler could bolt right on an was curved good to push snow back down. So drilled a few holes and it fit right on did not even need to cut to length. Worked great last winter. I love it when I find a use for stuff I refuse to throw out (closet hoarder)
Thanks for the ideas, the holes in the plow were there when we bought it through the dealer. Just for the heck of it, Monday I'll call the place we bought the plow from to see how much they charge for the snow guard for the model plow we have.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
YanMar SV40 Mini Excavator
YanMar SV40 Mini...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
iDrive TDS-2010H...
2010 CATERPILLAR 924H WHEEL LOADER (A60429)
2010 CATERPILLAR...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
