Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 25,282
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
As a fairly experienced hay farmer, Im looking at what youre doing from a completely different perspective. I understand why you want to do this, but you will struggle just to break even, more likely youll lose money on the hay end. Now that may not be an issue, but please dont think youll make money unless you have a LOT of tractor work you can do, or another source of income (I do construction).
If I were you, Id buy a used, proper farm tractor since it sounds like you want to do this as a business, not a pastime. Starting off with payments (even at “ zero “ financing) is going to put you in a hole that hay sales cannot keep up with. Id want to see you doing more of the other tractor work, say mowing fields and snowplowing, etc., before you even worry about hay. Remember, you are going to need a baler, disc mower, rake, Tedder and wagons if you do small bales and barn storage. Thats a LOT of capital investment. Its not just about a tractor.
I started out exactly the same way you did, and I wasted a lot of time on smallish equipment only to outgrow it and lose money on it while concentrating on hay.
If I were in your shoes, Id buy a good low hour, non tier 4 larger frame 75+ HP tractor with a cab and a loader before I bought a light weight small frame new tractor with all the pollution nonsense. Look around, youll see few for-profit farmers run a tractor like that. Only Personal or hobby use guys make hay with tractors like that. That way you can probably run a 12-15’ mower and a round baler or small square baler without breaking the bank.
Spend your money on new or newer attachments, not tractors.
