So how much trouble am I in ?
   / So how much trouble am I in ?
Soundguy said:
ouch!
what type of shear pin did it use.. grade 10?
soundguy
Don't know it was the original with the blower.
   / So how much trouble am I in ? #12
My father has a BX23 and 1/2 of the midshaft was left on from the MMM. He turned the PTO on not knowing it was there. Well after a few seconds of slamming the bottom of the tractor the repair bill was about $1500.00 at the local dealer. I dont think he will do that again.
   / So how much trouble am I in ? #13
It might be faster for them-your dealer
to do it if you are in snow country.
Lets hope the inner bearings are OK.:thumbsup:
   / So how much trouble am I in ? #14
How many hours do you have on your BX? I taken it is not under warranty. Has any of the dealers given a reason why the housing would break when it is normal to shear pins?
   / So how much trouble am I in ? #16
Less then 200h It's 4 years old. Dealer is closed today. Tuesday will be the day I realize just how much this is going to cost me. Without having the WSM to look at I'm thinking that the best plan is to remove the whole transmission assembly and have the dealer swap the case and put it back on myself. It's also going to ensure that the bearings are inspected properly etc.
Derek
   / So how much trouble am I in ? #18
good luck!
soundguy
   / So how much trouble am I in ? #19
Derek
Probably best plan. My reply did not address possible internal damage. Also get price diff between sending whole tractor vs transaxle...may not be worth your time to "explode" back half...
   / So how much trouble am I in ? #20
if out of warranty.. the rear of a salvage unit with front ed damage may be an idea.. places like wengers could put that on a pallate and freight it out.. etc.
soundguy
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2015 UTILITY 53FT REEFER TRAILER (A59905)
2015 UTILITY 53FT...
Lee Boy 250 Gal Tack Distributor (A53317)
Lee Boy 250 Gal...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
