socket size for Cat. I lower link pin. 7/8 inch diameter
   / socket size for Cat. I lower link pin. 7/8 inch diameter #1
splotkin
Western Ma
Kubota BX1850
I just got a CountyLine 5 ft rear blade from tractor supply for my BX1850. It is the same as King Kutter. It took a while to decide between the five and six foot blade. After reading the pros and cons about the different sizes on this forum, I finally went with the 5 footer as I am using it to move some gravel and re-grade the driveway which has a lot of clay in it. I was afraid the 6 footer would bog down.
I knew that I would need to reverse the lower link pins. I have sockets up to 1 1/4" half inch drive and figured all was set.
Well guess what? I should have checked before I left the store, which is a good 30+ minutes away. By the time I unloaded the blade from the trailer, cranked up the air compressor and got out the air wrench the store had closed. The socket I needed was larger than 1 1/4" in size.
I looked all over this site and others to find the size of the wrench to fit the nut. I found that the lower pin on a cat. 1 is 7/8 inch diameter, 2-1/2 inch usable length, 6-7/16 inch overall length, 7/8 inch NF thread diameter with fixed shoulder. OK, but what is the wrench or socket size?
I know that my 1 1/4" socket is slightly too small. I will hit sears in the AM but I need to know the exact size. Is it metric? I hope some-one out there knows. My best guess is 1 3/8" but want to confirm it.
Thanks,
-Scott
   / socket size for Cat. I lower link pin. 7/8 inch diameter #2
You could measure it.
   / socket size for Cat. I lower link pin. 7/8 inch diameter #3
you actually should
   / socket size for Cat. I lower link pin. 7/8 inch diameter #4
I can't remember the size. But, I do remember it wasn't what expected to be.
Sears may not have sockets or box wrenches big enough. Last time I went there for big sizes I left empty handed. 1-1/4" was the largest I could find. They probally will have 3/4" drive????
Just trying to save you a trip.
Thanks RickB.
I did measure the nut and it is very hard to distinguish between 1 5/16th and 1 3/8th. My guess is it is what you listed. When I put on the 1 1/4 socket it was so, so close to fitting.
Thanks,
-Scott
   / socket size for Cat. I lower link pin. 7/8 inch diameter #7
Thanks RickB.
Thanks,
-Scott
May be metric...
   / socket size for Cat. I lower link pin. 7/8 inch diameter #8
why not just get an adjustable at sears? a 15" cost 42 bucks or so and opens 1 1/2". a local aubuchon should have a generic for less (39.00). a home depot should probably beat either of them. or you could visit job lot and get a throw away model for cheap.
on the other hand, a pipe wrench would work, it's not like you're going to be putting these on and taking them off regularly, so why not?
I measured the nut and headed out to sears. They had a 1 5/16 inch open wrench. It is a bit sloppy but did the trick. The problem was the nut and lock washer were so tight I was afraid I would break my 1 1/2" adjustable wrench. The new 1 5/16th with a 3 foot cheater bar finally did the job. I am still not sure of the size. I put my calipers on it and it was 1.31 inches or 33.3 mm. which is a little less than 1 5/16ths. At least it is done. Now, if the rain would only stop!!!
Thanks,
-Scott
2015 MACK CXU613 SLEEPER TRUCK (A45677)
2015 MACK CXU613...
2016 FORD F-150(INOPERABLE) (A47001)
2016 FORD...
PIPE RACKS (A47001)
PIPE RACKS (A47001)
John Deere WHP36A (A47307)
John Deere WHP36A...
John Deere TX 4x2 Gator (A47307)
John Deere TX 4x2...
2012 Jaguar XJ Sedan (A46684)
2012 Jaguar XJ...
