Solis SV24 Electric tractor - Here is what we know so far...
   / Solis SV24 Electric tractor - Here is what we know so far... #51
Why don't they make one (with good rechargeable batteries) so it's covered in solar cells (where the mud doesn't land) and is designed to be left sitting outside 24/7?
There's just not enough surface area, and much/most of it isn't going to be at the optimum angle to absorb solar energy anyway. IIRC there is 733 watts per square meter of energy coming from the sun at the equator at noon on a perfectly clear day, and current solar technology is only 20-25% efficient, so you're looking at more like 150-180 watts per square meter. That's why it's far better to have a fixed solar install that has more surface area and can be placed in an unobstructed area. Really, the best thing we'll probably ever have is the flexible roll-up solar panels that can easily be hauled somewhere and laid out.
Ok -- I have two questions -- Why would anyone want one? What problem is this trying to solve?
The electricity is still coming from fossil fuels (natural gas, coal), nuclear, some hydro, and virtually no wind/solar.
You're assuming I'm doing this for environmental reasons. Not so... I want a more reliable, quieter tractor, with fewer moving parts.
It's pretty inefficient to transmit that electricity and then charge a battery repeatedly. If you drop all the lop-sided government subsidies, it costs more to "fuel" an electric tractor than a diesel tractor.
Gasoline engines are in the 25-30% efficient range today. Diesel is better, but still only 30-35%. An electric motor is about 90% efficient. In addition, my house can be my fueling station, so I don't have to run out and fill cans any more.
It will only run for a few hours and then needs to take a long rest while it's being charged. Diesel can run nonstop around the clock.
That's all I need it to do. If it can do 2 hours under a load, it'll take care of 95% of my needs. If it can do 4 hours under heavy load, 100% of my needs. Then, it can sit overnight and charge. In fact, it'll usually have several days to charge in between.
I can't carry fuel to it. If it quits, I can't pour a gallon of electricity into it to get it back to the barn.
So don't run it out. In a real pinch, a generator or an extension cord might do the trick, but it's better to just not run it out.
We already have a power grid that's FAILING in many locations during extreme weather. Why would we want to add additional load that has more efficient fuel options? (Just wait till they start trying to charge EV semi-trucks, etc. )
That is easily handled by charging at times when the power grid is underutilized. Currently, overnight is the lowest usage on the grid. More solar would obviously change that equation, but it's very easy to avoid peak times. Every EV can be programmed with your utility's off-peak times to take advantage of time-of-use charging, and there's plenty of smart chargers as well. Finally, with V2L technology, EVs can be used to help the power grid in extreme conditions.
Despite the fact that the government will likely steal some more of our tax dollars to offer obscene subsidies, the true actual cost is higher than diesel. If it costs more and doesn't solve any problem, what's the point?
They should be simpler to build once companies figure out how, and with far fewer parts and far less vibration, maintenance costs and time should be much lower. Plus, it'll be nice and quiet. Those are all really good things in my book.
The free market should drive innovation and product development. I just can't see how this makes engineering sense or economic sense.
There are things that can be done with battery weight that could be very helpful with tractors, and that's the kind of engineering I'm interested in doing.
The only way I'd maybe and that's a big maybe go near an electric vehicle is a hybrid and then the chances of me even go that route is next to nil. The cost of replacement batteries, the life of them makes it seem , to me anyway, a fools choice and that's just my thoughts.
The whole battery replacement thing is largely overblown, thanks to lots of FUD spread by the fossil fuel industry. The battery on my car is supposed to still have 80% capacity at 750,000 miles. It will outlast me. In addition, most batteries are made of several modules that can be replaced individually in the event of a serious fault. I have literally zero worry about replacing batteries.
I've always used this scenario as an example.
Say I have a 50km round trip to work every day so that's 250kms a week, say 300 for round figures. Friday night something happens and I have to go out on a 50 km trip but since I only charge the car once a week so I don't ruin the battery, I can't go as the battery is almost dead.
That's not at all how it should be done - You should plug it in whenever you're not using it, and let the battery management system take care of things. That's one of the things I love about electric cars - You leave the house with a full "tank" every day, and you never have to go out of your way to charge it, or stand out in the cold waiting for it.
Same timeframe, we have a storm go thru and the power goes out for 30 hours which it did just a couple months back. How do I even go out for necessities?
You just go, because it was probably already fully charged before the power went out. I have a friend whose house is set up where he can power his essentials from his car in the event of an outage - For days!
I question the APPLICATION of the technology. I don't dislike it. "The right tool for the right job" doesn't equate to an electric tractor (except in the most unusual situations).
It would work great for me, a homeowner who needs it to work for a few hours a week, and be reliable and quiet. And I don't think that's particularly unusual.
   / Solis SV24 Electric tractor - Here is what we know so far... #52
Regardless of the tractor brand as an EV, the two in my town are ka-put right now. And so is the full EV bus! Temps for over a week have not left the negative double digits for over night lows. The blowing snow has been a huge problem to remove and no EV tractor is available to get the job done in town. Then today I read about the Teslas in Chicago totally dead all around the city. People are stranded and paying big money at the downtown hotels till it warms up. One guy paid a towing company to move his EV vehicle to Milwaukee.
EV tractor for me, no way. Hybrid EV tractor, a better possibility as I see 'certain' benefits. And I would only pick a diesel+EV hybrid too.
   / Solis SV24 Electric tractor - Here is what we know so far... #53
I watched the Tractor Time with Tim video on YouTube where he was mowing with Solis battery tractor. I think it was a 5 foot flail mower, so nothing huge. Going slow, he had enough power to get a nice cut, but if he sped up, the cut deteriorated. It didn't have enough power at full charge to give a good cut on short grass.
The tractor lasted about two hours of mowing and he was in limp mode getting back to his shop. He wasn't able to mow the entire field. I don't remember how long it will take to recharge it so he can mow for another two hours, and I don't know how many times he'll have to charge it to mow the entire field.
With the cold weather, another concern has come up. How much damage to the battery does the cold cause? What happens when the battery can't hold a charge anymore? Who is gonna buy a used battery powered tractor? Why would you?
   / Solis SV24 Electric tractor - Here is what we know so far... #54
Miles.
What about years of battery life ??
When I do a search of ev battery life I'm seeing 10-15 years or 15-20 years.
All our vehicles and tractors are older than that.
What happens in 15 years and the battery is junk and replacement cost is equal to or more than the value of the vehicle.
Then what throw the vehicle away??
   / Solis SV24 Electric tractor - Here is what we know so far... #55
With my Yanmar diesel a kin to the Solis, I can cut nearly 24 acres on 5-gallons of diesel making the pasture very attractive.
Until a better battery tech comes along, we are stuck in these early generations of machines. I heard there is something called the Active Silver Lithium battery tech coming. Tesla is ventured with this tech. 5X more the range, charges FULLY in 18mins, will not over charge, very little charge resistance, and more pluses. Yet, it's like 3 to 5 years out before we see it in production. A battery like this would solve many woes right now.
   / Solis SV24 Electric tractor - Here is what we know so far... #56
Miles.
He said, 80% capacity at 750,000 miles.
What he didn't say was, at ambient temps. Who has ambient temps all year round ? We are in the negatives for over a week, and the low is double negatives. I've seen NO EVs on the road right now.
The cold kills the battery life, as in decade years to a few years. That 750,000 will drop like a rock for the full life of the battery.
   / Solis SV24 Electric tractor - Here is what we know so far... #57
Here's where I have a problem with battery tractors.(or cars, I tend to keep them for decades also))
Lets say you average 100 hours per year for 15 years.
The tractor is in excellent shape but the battery pack is bad from age.
Now what, throw the thing away because the battery cost is as high as the value of the tractor.
Sorry, think I'll pass.
My current tractor is 23 years old, working like new and plan on using it for many more years.
   / Solis SV24 Electric tractor - Here is what we know so far... #58
That is a consideration. People seem to be very guarded about the cost of the battery in these units. I can look at the cost of an engine at any time. CNH still will not publish an MSRP for the tractor they are currently selling that is electric. Why? Everything is shrouded in secrecy
   / Solis SV24 Electric tractor - Here is what we know so far... #59
My tractor is 38 years old and still running strong. I'm pretty sure you won't see any electric tractors that old even with a restoration. The batteries will just be too costly. And it's not like anyone will be able to restore the batteries at home. You won't be able to buy a battery pack from Tractor Supply or Walmart and bring home in the trunk. The batteries are so dangerous, they don't even want you to park your EV in the garage.
   / Solis SV24 Electric tractor - Here is what we know so far... #60
The more popular tractor brands and models hold their value. If you paid $30,000 for it ten years ago, odds are very good that you could sell it for $30,000 today, or even more then you paid for it. I paid $55,000 for my Massey 4707 a year and a half ago, and I'm seeing used ones being listed for $60,000 with more hours.
I don't see that happening with a battery powered tractor.
Looking at used prices for Tesla's, it seems that the price is half of new ones, once they break 50,000 miles. A few with over 100,000 miles are really, really cheap!!!
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
JOHN DEERE R4023 LOT NUMBER 261 (A53084)
JOHN DEERE R4023...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
