Some Incredible Sketchup Models
   / Some Incredible Sketchup Models #11
For 2D I found "DraftSight" which seems to be as powerful as AutoCad with zero cost. Someone at work complained they could not open a drawing from a newer version of AutoCad. As an experiment I was able to open it in Draftsight and save it to an older AutoCad format they could open.
I am spending hours almost every night learning Sketch. It starts to go fast once you get the extrude thing (push pull tool).
When I am dragging a rectangle to form something, I still struggle to get the final point to be exactly where I want it. I know I can type in dimensions but that does not help when I don't know them.
Ah the fun of it all!
Need to design a house... not sure why I didn't think of this sooner, doh!!!
A trick I learned when designing a small workshop space is the use of components. The nice thing about components is that when you change one, every other copy you have made of the same component changes too. For example, I made a 2X4 component for the walls. I wanted to see how the space would feel with a taller ceiling, so I lengthened all of the 2X4's at the same time by changing one of the components. If I ever need one of the components to be different, I right click and make it unique.
For you enthusiasts, here is a model of a fully functioning excavator that works with the sketchyphysics plugin.
   / Some Incredible Sketchup Models #13
Actual real live professional CAD software costs about $4500 per seat. You can down load a trial version of AutoCAD for free and try it for 30 days. Then you can get an idea of what it's really like and not fool with the Google toy.
If you want to export to tools or cutting tables you need this.
Play, the technical term for that is "instanced geometry"
I'm not going to argue the merits of professional AutoCAD software when coupled with professional AutoCAD users. I have no doubt that it's everything it needs to be and much more. When needed it is likely the only tool that will do the job.
There are a lot of things I can do with $4500 and the many months it would take to really learn AutoCAD. For no money and a few hours here and there of tinkering, I have a software tool that does everything I need it to and more.
   / Some Incredible Sketchup Models #15
Thanks "Iplayfarmer"
You saved me hours of experimentation with that tip. I remember when I started learning Paradox and Access database design, also Dreamweaver, I spent days with the tutorials but all it took was 5 minutes from someone with practical experience to resolve the tricky bits.
Cheers
Alan
   / Some Incredible Sketchup Models #16
Designing a house in SketchIt is a foolish choice. Chief Architect or its low end user version "Home Designer" is a WAY better choice! You can design a basic rectangular Ranch house in an hour or so and then print out complete floor plans, framing plans, material lists and 3d views. It is the right tool for the job!
But if you want to drive a screw with a hammer... well good luck to you!
I have all but given up on 3D Cad. Especially for a one off project. It takes me longer to design something than it does to build it. And if I don't use the software everyday I have to relearn it every time I want to draw something. (I have been a computer geek for 20+ years now. But I still have the drafting table I built in High School with a drafting arm.)
I do miss Generic Cadd! (DOS version of course!) Geeze could it make an incredible print on a Dot Matrix printer!
   / Some Incredible Sketchup Models #17
Tried that! I'm not being lazy and have been through the tutorials, so it would be appreciated if someone could advise where to look.
I prefer to draw each object to a specific dimension - say a line 3200 mm long. So far, it seems possible only to draw the line, dimension it, then adjust it to the desired length. There must be a better way.
Alan
Then perhaps you need a cad program that does that. I have graduated to the Solidworks platform and like it. I have learned that it can be as intuitive as Google Sketchup but at a MUCH higher cost. They have Sketchup8 now, maybe I will revisit and comment on what I find.
I'm not a high end user, but I haven't seen much in Sketchup 8 that wasn't in any of the earlier versions. I looked into solidworks for the capability to make interactive 3D components that can model motion and force. There is no way I can ever justify the cost of these programs. For as much as I'd use any of it I could probably pay a professional to design something for me and still not spend as much as I would on the program alone.
I was excited to find the Sketchyphysics plugin. It's nowhere near the capability of Solidworks, but at least now I can do some basic 3D modeling in motion. I haven't looked at any of the other plugins, but there are dozens made. I guess that's the beauty of an open platform software.
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
2015 PETERBILT 389 (A53843)
2015 PETERBILT 389...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
JOHN DEERE 437E...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
