prichard
Veteran Member
There's a registration?
OK, bare with me on this, and try not to laugh too hard. I purchased a 160 and it should be here next Monday (pushed back from tomorrow by UPS). My plan was to switch out one of the 220 plugs in my garage to the outlet mentioned above. That's when I realized... I don't have a 220 plug in my garage like I thought. :mur:. So... short of trenching a semi temporary outlet from the basement to the garage (tri-level house, garage is separated from basement by about a 10' entryway on a pad, no easily accessible walls to run new wire, etc) do I have any feasible options? Or will I just be holding onto the welder until I get my pole barn built... in a few years.
If you don't have a 220-240 volt outlet I don't know how you are going to operate it. Of course you can temporarily wire up a receptacle from the load center (breaker box) to test the machine. And I would recommend testing upon arrival. Then put it away until you get your power source. It will run fine off of a 30 amp dryer plug. Do you have an electric clothes dryer nearby?
