Something thats been bothering me.
   / Something thats been bothering me. #11
That is suspicious that its blank. I have owned over a dozen Fords and all as a axle code. It something like 31 or B6. On Fords, if its two numbers its usually a open diff, but if its a letter then a number its a limited slip diff.
This is not right. A 4L10 axle is a Ford 8.8" axle used on Explorers and Rangers, not Expeditions. It is a 4.10 LS though.
Chris
The tag will also have the pinion size stamped on it (9.75 or 10.5, for example). If the tag is stamped 8.8 4L10 , it is the incorrect tag. If it is stamped 9.75 4L10, then you have a 9 3/4"" ring gear witha 4.10 limited slip rear end.
   / Something thats been bothering me. #12
Chris
The wifes F350 has a tag on the axle that says "4L10" and it is a Sterling 10.25 axle with 4.10 gears and a limited slip. The previous owner said it was changed to 4.56 gears but I pulled the diff cover off and it had 410 stamped on the end of the pinion.
   / Something thats been bothering me. #13
I guess I was miss informed. I thought the 4L10 was only a code for the 8.8 Makes things confusing.
Either way its a 4.10 with a limited slip.
Chris
2012 Ford F-450 Knapheide Service Truck with Liftgate (A51692)
2012 Ford F-450...
2017 Freightliner M2 106 T/A 4,000 Gallon Water Truck (A51692)
2017 Freightliner...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2015 CHEVROLET C3500 SERVICE TRUCK (A51406)
2015 CHEVROLET...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
