Sonotubes
   / Sonotubes #1
Pettrix
Platinum Member
High Desert Southwest
Has anyone poured/used a 12" diameter Finish Free Sonotube?
Looking to pour a column that is 10 feet tall and 12" in diameter and the Sonotube forms allow for a clean finish. I know bracing is vital as is vibrating but just wondering how difficult the process was and how well the removable forms worked?
Finish Free(R) - Sonotube
   / Sonotubes #2
I don’t claim to be a concrete engineer but 10 feet tall seems like a lot to ask from a 12” column.
   / Sonotubes #3
I've used precast columns several times with good success. Because they are circular, they are strong. The ones I used were hollow in the middle and carried a bunch of weight from a front porch roof. Might be less expensive to use those instead of pouring a solid concrete one, with yardage minimums, vibration rental, labor and hassle. A good lumber yard will have several to choose from depending on your application.
Just my 2¢.
   / Sonotubes #5
I'm pretty sure a 10' vertical column is going to need more forming than a 3/8" cardboard tube.
This x2, A guy I know poured 6 foot tall tubes with "some" lumber bracing and it was a nightmare scenario with tubes leaning and even falling.
I saw it after the disaster so I don't know how much support the tubes actually had...beware:eek:
   / Sonotubes #7
I calculated 1.16 cubic yards of concrete which is more like 4000 pounds if my math is correct.
   / Sonotubes #9
Your correct. The formula is pi times the radius squared times the height. I used the diameter of 12 inches instead of 6 inches.
   / Sonotubes #10
A radius of 12" (24" diameter) gives you 4,200 pounds, or 52 80 pound bags.
But either way, I wouldn't consider it without extensive exterior bracing and a rebar cage to be embedded.
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
JOHN DEERE 6430 PREMIUM TRACTOR (A60430)
JOHN DEERE 6430...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
205196 (A52706)
205196 (A52706)
