Source for hydraulic cooler fan
   / Source for hydraulic cooler fan #1
Frank Sorbello
Power Trac PT-422
I need to replace my hydraulic cooler fan for my pt-422. Anyone know a good source for replacement?
thanks,
Frank
   / Source for hydraulic cooler fan #2
Several folks have said auto junk yards.
   / Source for hydraulic cooler fan #3
   / Source for hydraulic cooler fan #6
Purchased two 12" fans off ebay for $34 and free shipping. Look just like the original, except two of the four mounting holes don't match up.
Fan is not coming on after running hydraulics for a while. There is a oil cooler thermal relay in the manual. How do you check to see if that is working properly? Is that a common part or something I need to go through PT to get?
Thanks
   / Source for hydraulic cooler fan #9
First, make sure the fan works with 12V across it.
If fan works, then,
Suspect the fuse for the fan.
If fuse good, then,
Suspect the thermal relay.
Put a meter on it. It should be open when cold.
Run up the tractor for 20-30 minutes and put a meter on it again. If its still open, its probably bad.
Mine went bad about 5 years into ownership. I just bypassed it and hook the fan to 12V directly each time I run the unit. Someday I'll repair it, maybe.
   / Source for hydraulic cooler fan #10
Thanks
Put a hair dryer or heat gun on the thermal switch.
RoGator RG1100C (A56438)
RoGator RG1100C...
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
Polaris Ranger (A56859)
Polaris Ranger...
JOHN DEERE 844k-II AG HANDLER WHEEL LOADER (A60429)
JOHN DEERE 844k-II...
Greenworks Commercial 82V CZ60R Zero-Turn Mower-DEMO UNIT (A56438)
Greenworks...
