Spacers for Lawn Tractor wheels
   / Spacers for Lawn Tractor wheels #1
preacher1
Meta, Missouri
LS MT342HC
I have a slope that must be mowed across that I slide half off the uphill side to keep wheels on the ground. Has anyone put a spacer on a lawn tractor's wheels to widen it for stability? I have a John Deere 110, which is not a big tractor. Would loading the tires be possible?
   / Spacers for Lawn Tractor wheels #2
There are specs both from Deere and the transaxle manufacturer on allowable load weight available. Not sure w/o digging, but they aren't very much. More aggressive tire tread help?
It is just the tip over factor that worries me.
   / Spacers for Lawn Tractor wheels #4
While not a 110, this guy put on dualies :) He sells aluminum wheel spacers from 1" up so could give him a call and see what he says. Local dealer should be able to help also.
   / Spacers for Lawn Tractor wheels #5
My dad had tractor type tires on the rear and wheel weights on his 110.
   / Spacers for Lawn Tractor wheels #6
When I had my JD lawn tractor I filled the tires, 99% filled. I also have hills that I need to mow across. This improved traction and stability. It will reduce the life expectance of the trans-axle. I had to replace mine after 11 years which I considered fair
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
71052 (A49346)
71052 (A49346)
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2016 Ver-Mac S/A Towable Trailer Message Board (A49461)
2016 Ver-Mac S/A...
2022 Case IH 8250 4WD Combine (A50657)
2022 Case IH 8250...
