Sparks out of diesel exhaust?
   / Sparks out of diesel exhaust? #1
SteveM
Upstate NY
Kubota B7100DT
I have a 25 yr old Mitsubishi Beaver compact which has been a handy and reliable worker for me over the last couple years. Last nite, while plowing snow in -5 F temps, I noticed a couple times when the engine lugged a bit (letting out clutch in high gear) a couple sparks shot out of the exhaust....
A couple points of background info:
1) This seemed to happen only a couple times when the engine was still arguably warming up (I have block heaters on the tractor etc)
2) It was running fine, and since I dont normally use it at night, this may not be a new behavior.
Any ideas on why? Normal for an old girl?
THanks /forums/images/graemlins/smile.gif
   / Sparks out of diesel exhaust? #2
Normal for my John "its not a yanmar" Deere since new.
   / Sparks out of diesel exhaust? #3
It's normal. The soot blows out hot. Watch a train switching yard. They idle the locomotive diesels all day then power up to move & flames will shoot out the top. They have fire trucks in the yard during dry spells to put out small grass fires along the tracks.
   / Sparks out of diesel exhaust? #4
Sparks are a common diesel problem. John Deere has a optional spark arrester available for thier CUT's for about $15 as their exhausts are low mount. My 4310 exits near the front left tire.
   / Sparks out of diesel exhaust? #5
If sparks are a concern, there are plenty of aftermarket spark arrestors. In California, many of our tractors come with spark arrestors. Mine did as have my neighbors. I have since removed mine and have yet to see a spark.
   / Sparks out of diesel exhaust? #6
I have had lots of sparks in an old Ford 1720 with very little maintenance. Is there an arrestor for this model and what overdue maintenance should I do first? It needs a lot of tlc since it has been so neglected.
   / Sparks out of diesel exhaust? #7
wow , Good question I have that same model and as I read this thread title I said to myself I ahve NEVER seem sparks from it.Could it just be carbon particles that were burning ?They make it right through the muffler it seems..
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
(3) 55-Gallon Drums of Fertilizer (A51573)
(3) 55-Gallon...
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
