Speedi-Sleeve for worn shaft
   / Speedi-Sleeve for worn shaft
Huh?
Not sure i follow you....I can't imagine the gear casing not being designed oil-tight - maybe not water-tight....
Anyone else getting contaminated front end gear oil this frequently??
   / Speedi-Sleeve for worn shaft #12
I don't know how your front end is designed, my comments are only related the front axle on my 1110. I know that when I got my tractor the front axle was very low on oil and what remained was mostly water. When I tore the axle down, I could see that water was getting in the top of the axle where the steering arm is. The water could sit on top of the axle until it could seep in. This was evidenced by the shaft being rusty and the upper bearing being in very poor condition. When I put my axle back together, I made a point of carefully resealing it. Especially the oversized knuckle seal. Bearings and water don't mix. If you want to make excuses that it's only a tractor, then don't be disapointed when your tractor only becomes a piece of junk. Ask Gbirky. The guy he bought his tractor from had the same opinion.
   / Speedi-Sleeve for worn shaft #13
</font><font color="blue" class="small">( If you want to make excuses that it's only a tractor, then don't be disapointed when your tractor only becomes a piece of junk. Ask Gbirky. The guy he bought his tractor from had the same opinion.
)</font>
/forums/images/graemlins/confused.gif Don't understand where this comment comes from? or why? /forums/images/graemlins/confused.gif
   / Speedi-Sleeve for worn shaft #14
</font><font color="blue" class="small">( For the large seal groove - I'm going to try some good hi-metal epoxy - they aren't as deep and weren't leaking....just a weep )</font>
I think I'd solder or braze it up then polish down before I used a glue on it.
I imagine a good silver solder will hold up better than any goop.. and brass will be even better.
Soundguy
   / Speedi-Sleeve for worn shaft #15
</font><font color="blue" class="small">( </font><font color="blueclass=small">( If you want to make excuses that it's only a tractor, then don't be disapointed when your tractor only becomes a piece of junk. Ask Gbirky. The guy he bought his tractor from had the same opinion.
)</font>
/forums/images/graemlins/confused.gif Don't understand where this comment comes from? or why? /forums/images/graemlins/confused.gif )</font>
I misread another post. My bad. /forums/images/graemlins/blush.gif
   / Speedi-Sleeve for worn shaft #16
Brazing would be the best more than likely or that is defiantly what I would prefer.
   / Speedi-Sleeve for worn shaft #17
That or those new alloy solder rods that will solder aluminum and pot metal.. soundguy
Soundguy
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
2016 Ram 4500 Chassis Truck, VIN # 3C7WRKFJ7GG229313 (A51572)
2016 Ram 4500...
