Spencer's Pole Barn Project
   / Spencer's Pole Barn Project
Re: Spencer\'s Pole Barn Project
Here is a picture of the boom pole I used to set all the poles. Here is a <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=158132&page=&view=&sb=&o=&vc=1>link</A> to a thread on the boom pole.
   / Spencer's Pole Barn Project #12
Great shots, thanks for the update.
Question, why did you feel you needed to go so far down (62 inches) for the pole setting?
PJ
   / Spencer's Pole Barn Project #13
Yeah, those inspectors can be pretty tough on you! Did you ever try bribing one?
   / Spencer's Pole Barn Project #14
<font color=blue>Question, why did you feel you needed to go so far down (62 inches) for the pole setting?</font color=blue>
Sounds like 5 feet to get below the frost line plus 2" for the thickness of the concrete cookie?
pajoube, By code I needed the poles to be 48" in the ground and another 4" for the concrete cookie. That meant I needed at least a 52" deep hole. I tried my best to get the whole site perfectly level but I knew I was off by a couple inches here and there. So I figured that I would go extra deep to ensure that I had all the poles at least an extra 4" to 6" after I got the site perfectly level. All the posts were longer than needed and I just cut them all to the right height just a couple of days ago. The closest call I had was one of the 4" x 6" posts that the glulam beam rests on, I only had to cut 1.5" off of it.
Here is a picture after I got the first five posts set in place. I was so happy to finally see this thing start to go up.
   / Spencer's Pole Barn Project #17
Spencer - I know what you mean about having kids making it hard to get things done. I don't know how other people do it. I can't seem to get anything done! What did you use to level the fill that you had brought in? 260 yards is a LOT!
Here is a picture of me filling the first hole up with concrete. The posts are sitting on a 4" thick 16" wide concrete cookies. I drilled holes near the bottom of the posts and pounded two 10" spikes through them. I shoveled in around 8" of concrete into the holes. I then tamped the concrete with a hoe trying to slope the concrete away from the post on each side so that water would not collect there. The holes were a little wider than 18" so the concrete went around the cookie and then up around the posts. I had bought a 3-point cement mixer to mix the cement for these posts and to make some sidewalks. The mixer broke the first time I went to use it. It didn't have enough travel on my 3-point anyway so I ended up returning it to my dealer. You couldn't lift the mixer high enough to dump all of the cement out of it. I will probably end up getting an electric one later next year, but for now I have to mix it up in my tractors bucket.
Mosey, I don't know how everybody else does it either. I was 33 when my daughter was born so I was pretty set in my ways. I think most people have their kids when they are in the twenties so the adjustment might not be as severe. I was in the doctors office a couple of months ago and there was a lady there with two kids. I said "I don't know how you do it, I can barely handle one kid". She said "It was harder for me when I only had one kid, now that I have two they can play with each other." Although I am sure that it is still harder to have two kids I think there might be something to that. My daughter is very demanding of my time, as she should be.
I am not sure what exactly you meant when you asked "What did you use to level the fill that you had brought in?". Did you mean which implement did I use to level the sand or what tool I used to check the level?
   / Spencer's Pole Barn Project #20
I meant "what implement?" I've read other posts and have some myself on this subject, such as <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=implement&Number=45902&page=&view=&sb=&o=&vc=1>how not to make whoop-de-doos with a box blade</A>, and was just wondering how you were able to level off that much fill. If you did it without and guide/gauge wheels, then I'm thinking I don't need any.
I don't want to stray off topic, but the lady you talked to had a point. We have twins and it was real hectic for the first couple of years. But, now they have each other to play with and that helps a lot. Except, I fell real guilty when I'm busy with projects while they are off playing together. As a result, I've decided to put things off until they get older and can be a part of it or have something else they'd rather do like being with their friends.
2014 VOLVO VHD DAY CAB (INOPERABLE) (A50854)
2014 VOLVO VHD DAY...
TEST BID LOT (A50774)
Hydraulic Breaker Excavator Attachment (A49461)
Hydraulic Breaker...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
