spendy fan clutch
   / spendy fan clutch
is that rock auto actually selling an oem part or a 'like' oem part, as it sounds like the motorcraft 'crossed' umber that napa gave me.. same price too.
I've heard those clutches are more agressive, thus more overall fan noise from longer / faster lock up.. etc.
I also understand this is a centrifugal / hud style clutch.. or at least believe it is.
soundguy
   / spendy fan clutch #12
so living in FL... you have to ask yourself... why replace the fan clutch?
Seems like the smart choice (for you FL enviroment) is to just go with a aftermarket hard mount fan. cost... $45-80
in short F the fan clutch....
   / spendy fan clutch
that things pretty drn loud when it comes on! I don't want to hear it all the time.
Usually I can only get the fan to come on when towing.. just tooling around town isn't enough load.
soundguy
   / spendy fan clutch #14
The 7.3 diesel has a very oversized cooling system. Most of the time, regardless of outside temp, you don't need the engine fan. International/Ford decided to equip this engine with a monster fan that will suck seagulls off of a landfill when it is engaged. These features lend themselves very well to a non full-time fan. You did right to replace the failed clutch.
I work around dumptrucks and those are also equipped with a fan clutch but it is electric and when that bugger engages it squeals the belt and makes a hurricane of wind. Very similar to the 7.3 diesel.
The idea of an HD fan clutch system is that the fan needs to be able to move enough air to cool that huge engine under full load while the truck isn't moving fast. If it moved that much air all the time it would be a problem in terms of noise and fuel consumption.
   / spendy fan clutch
yep.. it is a monster fan.. and you are correct. when it comes on.. you can even hear it in the cab going down the interstate doing 72 mph.. and that is with the engine tach'd at 2750 as i have a 4.88 rear end.
again. only comes on when hitched to a trialer.. can't make it come on without towing.
it was spendy.. but my gut feeling was to replace it correctly with the oem reccomended part. i don't forsee being able to buy another dually for a looooong time with my job and the economy as it is.. so i can't afford to screw this one up by not repairing it well.
soundguy
   / spendy fan clutch #16
soundguy
AFAIK RA is selling "real" Motorcraft parts and not off-shore knock-offs because they look exactly like the parts dealers install (appearance, weight, boxing etc) are all the same.
NAPA parts (the pro stuff like United & Belden) are often OEM parts w/o the OEM box or marketing (etching/embossment etc) on the part. In some cases, the OEM p/n is still visible!
   / spendy fan clutch
thanks for the info.
soundguy
2021 TAKEUCHI  TB260 (A58216)
2021 TAKEUCHI...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
SKLP Massage Chair (A57149)
SKLP Massage Chair...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
2011 John Deere 6115D (A57148)
2011 John Deere...
Heaven Hill Bourbon Barrel (A57454)
Heaven Hill...
