Spike Aerator
   / Spike Aerator #1
carolinarider
Bronze Member
Newberry, SC
Massey Feerguson 1250
I would like to purchase a spike aerator so pull behind my MF 1250 tractor. I have found a couple but one issue would be moving it from point A to point B and not having the spikes engaged.
Are there any what have a system that I can attach some wheels to so that it is raised off the ground while it is being moved from Point A to Point B?
Just for the record, I intend to use it to aerate some areas that have heavily compacted soil with the hopes that if I can get some water and nutrients down below the surface I can get some grass to grow.
   / Spike Aerator #2
Mine is a Frontier 6' CA2072 that is 3 point mounted. I made a couple of weights with from plywood forms and sackcrete that fit in the top tray. I had some u shaped pipe from an old round bale feeder that I cut off and cast into the top of them so I can take the weights off with pallet forks if desired.
Works well digs good plugs and I used it on my pastures and lawn each year.
There are other brands that make similar ones that are 3 point mounted. The only reason I bought this particular one is because it sat on a local John Deere dealers lot for several years, never moved. I stopped in one day and asked did they intend to sell it or did they just like to mow around it.
   / Spike Aerator
So, I assume that a 3-point hitch aerator will allow me to raise it up for transport. Is that correct?
   / Spike Aerator #5
I had a TORO 3ph unit. Must have weighed two thousands pounds! The stones areound here were quickly destroying the scoop type tips, so I sold it.
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
2023 CIMC 53X102 REEFER TRAILER (A52576)
2023 CIMC 53X102...
2023 Dynapac cc900 Double Smooth Drum Roller (A51573)
2023 Dynapac cc900...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
