Spike Tooth or Chain Link Harrow?
   / Spike Tooth or Chain Link Harrow? #1
trook
North Central Mississippi
JD 5075E Cab
After disking for food plots, what implement is best for busting up the remaining clods and leveling the food plot for broadcast seeding....a spiked tooth harrow or chain link harrow (mat)? Also, please consider that this implement will also be used to cover the seed once it is broadcast.
:confused2:
   / Spike Tooth or Chain Link Harrow? #2
Not sure which is best but i use a spiked harrow after disking to break up clods and to get ready for seed then after a sow seed i flip harrow over and cover seed up seems to work great,
If I use a drag harrow, I will get one with a frame like the one on the left. The spiked tooth harrow is red and on the right. This is what I'm talking about:
   / Spike Tooth or Chain Link Harrow? #4
Ahhh then i would buy the spike drag and make a chain link harrow to cover seed.
   / Spike Tooth or Chain Link Harrow? #5
I don't know if the tooth harrow is adjustable but the chain harrow gives you 3 options: 1) very agressive with the tines nearly vertical, 2) turn it around for less agressive with the tines at about 45 degrees and 3) flip it over for a smooth drag (like to cover seed).
Also, the chain harrow does a great job to level/smooth a caliche driveway.
   / Spike Tooth or Chain Link Harrow? #6
I had a spiked tooth harrow like that one and I was very unimpressed with it, so much that I returned it for a refund. It was pretty flimsey, and was too light to accomplish much. It just bounced around.
Hard clods are hard to break up, and something heavy like a cultipacker works best. I have found anything you drag around just rearranges the clods, and may not break them up. On the other hand, breaking them up totally really isn't necessary, and some say having some clods remaining is good, as it prevents compaction and a hard baked surface. Last year it was so dry that after plowing, the clods were the size of concrete blocks and just as hard. It was a bear to break them up and it beat me to death driving the tractor over them. It took mutiple passes with a heavy disc harrow to chop them up, and then several cultipacker passes. Our timing was bad. Should have done this when it was wetter, but we did not have rain in late summer and early fall, so we had no choice.
What we do after plowing, and discing, is to drag a home-made drag made of heavy angle iron and chain. This levels out the high and low spots and gets things flat. At this time you could cultipack, to break up clods if they are bad, but isn't required. Then after broadcasting seed, we either use our same drag going fast or cultipack again. I will try to post a pic of our drag, but it is three 6' parallel lengths of 4x6" heavy angle spaced about 4' apart connected with a web of chains, with a chain tow harness on the front. Probably weighs 200 lbs and is indestructable. I have drug this thing 100 miles around our property. It also has the added benefit of dressing up the roads between each food plot. I made it out of scrap angle and about 60' of chain and eye bolts drilled thru the angle. Was easy and cheap to make. Another advantage is that someone can drag this with a truck and not tie up the tractor, and pulling it with an air conditioned truck is way more comfortable, and someone less skilled (like a teenager) can do this.
   / Spike Tooth or Chain Link Harrow? #7
Here are some pix. This drag really levels things out nicely, and is bombproof and cheap.
   / Spike Tooth or Chain Link Harrow? #8
This is my experience too. This type of chain harrow is very versatile.
   / Spike Tooth or Chain Link Harrow? #9
Thanks for the pic's.
Gave me some ideas for my needs. :thumbsup:
   / Spike Tooth or Chain Link Harrow? #10
This is mine. I've used it for some leveling and in my pasture to smooth it out. Went around my property edge where the farmers digger left some big chunks and it did a great job breaking those down.
E-Z-Go Utility Cart (A55851)
E-Z-Go Utility...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2017 Ford Expedition SUV (A55853)
2017 Ford...
2021 CHEVROLET SUBURBAN (A53843)
2021 CHEVROLET...
