Split-dovetail car hauler trailer
   / Split-dovetail car hauler trailer
Most of the cross-braces in. I was going to put built-in, flush mounted motorcycle chocks in, but changed my mind after ordering one and seen how cheap-like they were made. I'll fill in the front with more bracing.
Dove-tail roughed in, flipping it over to weld the other side.
   / Split-dovetail car hauler trailer #13
I used a grinder and cut-off wheel to cut out the openings for the ramps and used a mag drill to drill for the posts. 1/4" plate was used for the flip-up doors.
When my children were about your daughter's age, the also wore their boots on the wrong foot..good memories.
I didn't even notice her boots until I went to post it to this thread.
For gussets I used cardboard to get the shape I wanted then traced it onto 1/4" plate, I then cut it out with a cut-off wheel.
Gussets laid in place and burned in.
   / Split-dovetail car hauler trailer #18
:thumbsup: Watching.
Next I started on the ramps. They are made from 1/4" thick square tubing with the center parts 3/16" thick square tubing, they are heavy.
   / Split-dovetail car hauler trailer #20
Have you seen these? Biker Bar
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2011 MERCEDES-BENZ E-Class Sedan (A56859)
2011 MERCEDES-BENZ...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2011 Isuzu NPR 14ft. Box Truck (A56858)
2011 Isuzu NPR...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
40' High Cube Four Multi Doors Container (A55272)
40' High Cube Four...
